Go to Post There is no shame in playing the best match you can play. - sanddrag [more]
Unread 15-01-2011, 11:55
frenchie4111 frenchie4111 is offline
None #1111
frenchie4111 is an unknown quantity at this point
Multiple outputs
We have 4 buttons and each button controls the directions of 2 motors.
We have a case structure for each button where true sends a value (0.5, or -0.5) to the "Motor Set Output" and false sends a value of 0. We have run into a problem when we have multiple outputs set to a motor.
Attached is an image of the case structure for Button 1. We have tested it and it works. But we get lost when we try to add case structures for the rest of the buttons.
[url="http://mylifeisnerdy.co.cc"]My Life Is NerdyURL]
Unread 15-01-2011, 12:43
Re: Multiple outputs
One way I like to do this is to use multiple selects. See the attached picture. This assumes that only one button will be pressed at a time.
Unread 15-01-2011, 14:10
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
Read each button and put into a binary array. Then convert the array to a number. Your select case can then test for which number shows up. If you are watching four buttons, there would be a possible 16 cases. But since you probably only need to detect if one button is pressed, your test cases would be 1, 2, 4, 8. A very similar technique is being used in the sample line follower code that came with LabView this year.
If you need sample code, let me know. I will be at the lab tonight and can make it real quick.
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 16-01-2011, 23:45
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
If I really had to do something like this, I would make a subvi, using a typedef'ed enum. This enum would then be used on the case selector with the output options/code. This would allow future changes pretty easily.
Originally Posted by Joe Ross View Post
One way I like to do this is to use multiple selects. ... This assumes that only one button will be pressed at a time.
I have to say that this would become hard to follow whenever extra code is added. It would also be very difficult to scale, and modify into the future. (Like on competition day)
Mike B
Unread 16-01-2011, 23:55
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
Hey Jeff,
I was interested in seeing that code as a example that could learn from. Thanks!
Unread 17-01-2011, 00:40
SuperS_5's Avatar
FRC #1219
Here is an example. The zip is just the subVIs.
Mike B
Unread 26-01-2011, 17:40
robotjac robotjac is offline
robotjac is an unknown quantity at this point
This is the error code I get when tried to use the codes. Can you tell me what I did wrong?
Unread 26-01-2011, 17:52
1) Your Motor Output needs to be told which motor you are talking about.
2) You have not defined what to do with all the possible cases of joystick buttons. At the very least you need a "default" case to cover all uncovered bases.
Unread 26-01-2011, 18:33
Can you send me some screen examples? I'm new and I can't visualize what you're telling me. Thank you.
Unread 26-01-2011, 19:15
Here's what you need:
1) Add a Motor reference (this motor needs to be opened in Begin.vi)
2) Put the cursor on the cases and right-click to choose "Add Case for Every Value"
Then look for every new case that needs a motor value added to it.
The output tunnel carrying the motor value will be solid when you have them all. It'll have a white center if you haven't fixed all the missing cases.
ID:	9834  Click image for larger version
Unread 26-01-2011, 23:34
Thank you! Everything is working great now.
Unread 02-02-2011, 15:46
As an aside, here is how I would select between multiple joystick or custom DS buttons.
Unread 02-02-2011, 15:54
IisMathwizard's Avatar
IisMathwizard IisMathwizard is offline
Programming Mentor
AKA: Mathwizard
FRC #1248 (Titanium Allies)
IisMathwizard is an unknown quantity at this point
I would've broke both the motors up into two case structures and then have a boolean series hooked up to nested case structures.
jRIO 2013 Project
