Go to Post An opportunity is always there waiting to be discovered, we just have to look and then see what we can do to help create change. - JaneYoung [more]
Unread 26-01-2011, 22:38
James1902's Avatar
James1902 James1902 is offline
Chopsaw??
FRC #1902 (Exploding Bacon)
Team Role: Marketing
James1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond repute
Re: Team 1902 Roller Grabber Teaser
Originally Posted by George1902 View Post
Chop saw!?
...chop saw
-In case of major discrepancies it's reality that's got it wrong
-oink oink boooooooooooooooooooooooooom
-Iz it can b pig go boom time now plz?...kthanxbye!!
Unread 26-01-2011, 23:51
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Originally Posted by Cyberphil View Post
Very interesting! I am impressed!
Are you going to keep that speed? (I assume so). If so, do you have some kind of clutch system to prevent the cims from stalling, or a sensor on the back of the arm? Or nothing at all.
We are thinking of dropping the speed, but only slightly, using Banebots in place of the Cims as the Cims are probably overpowered for this application. The cims were all we had to prototype with. A "gripped" tube will be detected by a limit switch on the back of gripper. We are debating the need for an encoder to sense the rotation and control the speed.
The tube is captured by not allowing the wheels to back drive, if you watch closely when the tubes are released the wheels are driven backwards. We'll make sure to have the controls in place to keep that from happening.
The cool thing about the roller gripper is that it can allow for "easy" tube manipulation ala 233 in 2007. We found that this can be difficult on the points of the square and triangle but every semi circular cross section is mostly adjustable.
Adam, the tools in the video are at a mentors house, who was assisting in the fabrication of the gripper.
And of course this mentors house does come fully equipped with a chop saw.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 27-01-2011, 12:58
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Excellent! Looks great guys! Hopefully you make it to Einstein this year too!
Good Luck, and see you in Florida!
Unread 27-01-2011, 13:25
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I'm an avid believer that no shop is fully equipped unless it has a chop saw.
Also, can any of you guys expand on the Modulox system? I've been trying to find info on it, but it doesn't seem like there is much. Is it just a "universal" gearbox of sorts?
-Dustin Benedict
Unread 27-01-2011, 13:35
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Looks like an awesome prototype!
Horizontal band saw > chop saw.
Art Dutra IV
世上无难事,只怕有心人.
Unread 28-01-2011, 18:56
iR3 Creative
AKA: Dan Richardson
The Modulox system is a modular gearbox that utilizes keyed bearing blocks in machined slots to construct nearly limitless gearbox outputs, gear ratios, and arrangements. It uses standard sizes and hex bore gears (both .375" and .500") to make it easy to configure only requiring a set of Allen Keys. Their is a walk through at the top of Modulox.com website that describes how the system works. And the kits are being sold by AndyMark.com here:
We used it on our gripper for two purposes, to adjust the height of the rollers so we could dial in the perfect distance for the tubes as well as to adjust the gear ratios up and down a bit. It made the prototyping process quite easy.
/edit Oh and Art, you speak blasphemous words sir. Red dots coming your way.
Unread 28-01-2011, 19:02
Aren_Hill's Avatar
Build Nifty Things
We were just actually rearranging the MechE department machine shop at Iowa State.
The chop saw got stuck under a bench out of the way as everyone went straight for the horizontal bandsaw...
A guy who likes robots.
Unread 29-01-2011, 23:47
Chris is me's Avatar
AKA: Pinecone
How hard does it actually grip the tube?
