Go to Post Some said the aluminum foil gave the robot a NASA-like quality, but others pointed out that blanketing components with a highly-conductive material that blocked air flow was probably not going to help get us to Einstein. - beerobber [more]
Unread 25-01-2011, 20:40
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Encoder setDistancePerPulse()
So I hooked up our encoder and tried out both counter and encoder
all i essentially did was this:
roboInti{
sensor.start();
teleopPeriodic{
System.out.println(senser.getCount());
or
System.out.println(senser.getRate());
Now if I used a counter, I'd get crazy numbers. I'd run it for 5 seconds, and I'd get 448705 as my last number, which makes no sense.
If I used the getRate(), I get NaN
I'm assuming that I need to use setDistancePerPulse
I have the E4P, so what should I set as the distance per pulse?
Unread 25-01-2011, 22:31
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Encoder setDistancePerPulse()
Distance per pulse is something you set based on your wheel radius and other factors. The kit encoder this year is 1440 pulses per revolution (1440) thus 0.25 degrees per pulse.
Unread 27-01-2011, 02:11
el-zoroo el-zoroo is offline
Chief Operating Officer
AKA: Zuhair
FRC #2374 (Crusaderbots)
el-zoroo is an unknown quantity at this point
We had this same problem too. The quick fix appears to be to construct the Encoder with a 2x encoding type, i.e.
//Assuming Encoder is connected to DIO 1 and 2 and not reversed
Encoder sensor = new Encoder(1,2,false,CounterBase.EncodingType.k2x)
I do not know if it is a bug with the WPILib. Maybe someone else can confirm.
Hope that helps!
Unread 27-01-2011, 09:44
It's a bug in the fpga. http://www.chiefdelphi.com/forums/sh...ad.php?t=89257
Unread 31-01-2011, 12:14
FRC #1747
Hope that helps!
This definitely helps, but i get weird numbers like 0.0.0054465 and .00045678
Any idea what it means?
UPDATE
nvm, I did a powercycle and i got better numbers
what are the units the encoder returns?
Unread 31-01-2011, 18:10
AKA: Zuhair
The encoder returns distance per second. The exact units depend on what units you used in distancePerPulse(). I think you will have to divide the rate by 2 because of the 2x Encoding type.
Hope that helps
