Go to Post But that is not all-FIRST is about teaching mentors what kids are like all over again. It's about closing the generation gap, creating bonds, life time friends, and skills that will last everyone involved a lifetime. - Team0 [more]
Unread 27-01-2011, 08:48
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
pic: 816 as of 1/25/11
Unread 27-01-2011, 08:50
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: pic: 816 as of 1/25/11
That's a clean looking bot.
What does the underside look like? How do you put the wheels in?
Also, I don't see any chain tensioning features....care to expand.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 27-01-2011, 09:00
thefro526's Avatar
Mentor for Hire.
Thanks Anthony!
The underside of the tubes looks like the top, except the slots are two inches longer (6.5" long) to allow the wheels to be put in. The extra two inches of slot on the outer wheels is biased towards the center to maintain enough material at either end of the tube to keep some structure.
Right now there aren't any tensioners in place, the axles were placed apart so that we'd use a whole number of chain links (no half-links) so the chains are pretty tight. There are holes to allow delrin idlers to be bolted into the tubes to help tension the chain a bit, but we won't know if we need them until the chain stretches.
-Dustin Benedict
Unread 27-01-2011, 09:12
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Probably a question with an obvious answer, but is the tower side the front or back?
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 27-01-2011, 09:14
thefro526's Avatar
Mentor for Hire.
Not all that obvious of an answer, but the tower is in the rear of the robot.
-Dustin Benedict
Unread 27-01-2011, 09:16
dodar's Avatar
So to me that would mean that you guys are going to have a double-jointed arm? So that you can pick up from the front, unless you are gonna scoop from the back and score from both sides.
Unread 27-01-2011, 09:18
AKA: Anthony Lapp
We use a cam bolt for tensioning in our boxed frame system.....works pretty good. It is especially well suited for these applications because you have axle support on both sides.
A fixed center distance will do the trick too.
Anthony Lapp
RobotOpen
Unread 27-01-2011, 09:35
thefro526's Avatar
Mentor for Hire.
We're planning on using a 4-Bar arm with a wrist. I guess that's technically 2-joints, but the wrist will only pivot between 0* and 90* with the floor- which is to allow for tube pickup.
Anthony, I referenced your cam bolts during the design phase for this drive, but I didn't think they'd be necessary if we could hold a respectable center to center tolerance. If we find that tensioning the chains becomes and issue down the road, it's not hard to implement your tensioner on our drive.
-Dustin Benedict
Unread 27-01-2011, 10:19
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Wow Dustin! I am loving the direction you guys are taking this year. This robot looks so clean and robust. What are you planning for the gripper? Pincher or roller?
Mentor 2415
Unread 27-01-2011, 10:22
thefro526's Avatar
Mentor for Hire.
Thanks Sean, we're trying to make up for that thing we put on the field last year...
I'm currently working on finishing up the CAD of our Claw. It's pretty much a standard Polycord Roller Claw, nothing ground breaking, but it should serve our purposes well. If all goes well, it should be done Monday or Tuesday of next week, but with all this snow that may slip a bit.
-Dustin Benedict
Unread 27-01-2011, 10:43
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Saw this on facebook a few days ago and gotta say that this is gonna look real nice at NJ and Philly. Hopefully over the next two weeks, I'll be over to see it in action man.
By the way Dustin, that "thing" got you to the Finals in NJ last year. Just an fyi haha.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 27-01-2011, 10:50
AKA: Anthony Lapp
Cool.
Our sponsored team, FRC3098 The Kettering Captains, will be using our setup this season....so I'm really looking forward to see how the cam bolts hold up during competition.
Agreed that you could always go to a tensioned system if you start to see excessive sprocket wear.
Anthony Lapp
RobotOpen
Unread 27-01-2011, 11:00
thefro526's Avatar
Mentor for Hire.
Thanks bro. By the way, even if your team doesn't come to our field, you're more than welcome to stop by to chat robots and stuff.
Cool.
I'm curious as to how well they'll hold up to. By the way, where did you get your 3x4 Tubing? I've found that it's not a common size at any of our local suppliers.
-Dustin Benedict
Unread 28-01-2011, 13:50
J.Warsoff's Avatar
J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
Looks very good guys! Just wondering, are you guys using a minibot? If you are, how will you deploy it?
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
Unread 28-01-2011, 13:54
thefro526's Avatar
Mentor for Hire.
Our mini-bot is currently in development, so we're not entirely sure of a deployment system yet. Odds are that it'll either sit in between the uprights and be deployed from there, either using a piston or some linear slide, or be deployed from one of the sides.
-Dustin Benedict
