Go to Post There's nothing that you can do to please everyone. You have to figure out where you stand and hold your ground. - sciguy125 [more]
Unread 27-01-2011, 09:43
leobot_792 leobot_792 is offline
FRC #1591
leobot_792 is an unknown quantity at this point
Minibot Deployment
Alright, so we have been brainstroming on the actrual minibot deployment method for a couple of hours now. We have several "good" ideas, however, none seems to have it all. I understand that there's usually a trade-off, but not a single design pops out. any ideas?
Unread 27-01-2011, 11:41
Bernoulli Bernoulli is offline
Bernoulli is an unknown quantity at this point
Re: Minibot Deployment
in reality several teams are just gonna keep it simple using just drawer slides to push it out because its not so much of the deployment that matters but the speed of the minibot to reach the top =]
Unread 27-01-2011, 11:51
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
I disagree. If you have 4 minibots on the field that have similar speeds, deployment could very well make the difference.
Unread 27-01-2011, 11:56
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Every minibot has the same motors and power source, if properly designed many minibots will have very similar climb times.
OP:
Our team has been brain-storming too, I think one of the fastest ways is with a piston to push the minibot out. The trick is releasing it from the piston, which we haven't figured out yet
Unread 27-01-2011, 12:26
ESPbomb ESPbomb is offline
Junior Member
FRC #0610
ESPbomb is infamous around these parts
I very much agree. Minibots power sources are all the same, deployment is where the game will be lost or won.
ESP
Unread 27-01-2011, 12:48
FRC #1591
ESP
I agree that deployment matters, however who said that we will all have the same power source? who said we have to use a motor at all? there are many ways to make something move mechanically, you just got to find them and apply them.
Unread 27-01-2011, 12:55
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
The GDC did.
<G19> MINIBOTS must remain completely autonomous and move up the POST solely through electric energy provided after DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry).
Unread 27-01-2011, 12:59
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I said that we all have the same power source and motor(s). Eagle covered it.
Unread 27-01-2011, 22:25
FRC #1591
<G19> has drastically changed some things. Deployment will give the advantage. Also the mass and friction against surface area will have to be at perfect set amounts to achieve the fastest minibot. back to the drawing board.
Unread 27-01-2011, 22:28
liam.larkin's Avatar
liam.larkin liam.larkin is offline
We will find a way or make one!!
FRC #0272 (Cyber Crusaders)
liam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to behold
I see a lot of people saying G19 has changed a bunch. What has changed I mean they have clarified a bit. I think a combo of accuracy and speed and you will be fine. NO??
Unread 27-01-2011, 22:30
FRC #1591
yeah the world will continue to rotate...
