Go to Post Fans come and go... but if you're a diehard, you stick around during the losing seasons, too. - Amanda Morrison [more]
Unread 27-01-2011, 12:30
ESPbomb ESPbomb is offline
Junior Member
FRC #0610
ESPbomb is infamous around these parts
Roller arm - Wheel
Hello World,
I am in the process of designing a roller arm, which sucks in the tube with tread, and there are mixed views as to one aspect. One party thinks we should have an idle wheel at the back to minimize friction with the frame, and one party believes that if the frame has a curve at the back, a wheel is not needed.
Opinions?
Unread 27-01-2011, 12:34
Chris is me's Avatar
AKA: Pinecone
Re: Roller arm - Wheel
What would a wheel at the back accomplish? When would it spin and when wouldn't it? How would this spin reduce friction?
Unread 27-01-2011, 12:37
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Originally Posted by ESPbomb View Post
Hello World,
Opinions?
in 2007 my team had pretty much the exact design that you are speaking about. Our prototype had an idler in the back. We built the real thing, left off the idler for weight purposes, and found it made no difference at all. Just make sure it isn't rubbing on anything with friction, and if it is, coat it in any kind of tape you can find with a low friction surface. That's what my team did in 2007, and we had no problems with tubes binding in the back of the claw.
(Just avoid sharp edges, but that's pretty obvious).
Unread 27-01-2011, 12:38
Junior Member
FRC #0610
Well, a wheel at the back would be spun whenever the tube was rotating inside the tread. The idea is that we can run the tread in the same direction to rotate the tube vertically so it can be put on a peg. The wheel is there so that the tube will not be popped.
ESP
Unread 27-01-2011, 13:17
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
ESP
Prototype it to see if it'll work/is needed.
Art Dutra IV
世上无难事,只怕有心人.
Unread 27-01-2011, 14:17
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
I was thinking an idle wheel wouldn't really affect performance much. We're using the same design and we never even considered an idle wheel because it does about as much work as a slick surface.
