Go to Post While you look at it as punishment, I look at it as a challenge. - Daniel_LaFleur [more]
Unread 27-01-2011, 14:35
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Sending basic data to driver station
Originally Posted by DCRich View Post
Where do you find this ZomB dashboard? --- OK, I found the reference to this.
Where is the documentation on the SmartDashboard?
The SmartDashboard and ZomB dashboard are both projects on firstforge.wpi.edu. You don't need an account to access either of them, and the source code is included with both distributions.
Brad Miller
Robotics Resource Center
