Go to Post Unconventional isn't necessarily innovation. - AdamHeard [more]
Unread 27-01-2011, 14:02
Ethan Spitz Ethan Spitz is offline
President
FRC #3637 (The Daleks)
Ethan Spitz is an unknown quantity at this point
Re: Voltage regulators
Ethan,
The digital side car jumpers are there to supply 6 volts for servos. If you remove the jumpers there is no voltage. There is no easy way, using the digital side car, to provide 4.8 volts to the servos you linked to in your post. If the GDC allows this variation then we can discuss some alternatives.
So basically if they don't allow the voltage regulator, I'm going to have to find another servo :/
Ethan
www.team3637.com FIRST team 3637's Website: The Daleks
Unread 27-01-2011, 14:11
Yes.
Unread 27-01-2011, 14:54
riptide's Avatar
riptide riptide is offline
The Software Dude... LabView and VB
AKA: Jeff
FRC #1165 (Paradise)
riptide will become famous soon enough
Wouldn't the power converter included in this years KOP work?
360 CPR
12V to 5V, Step-down, 5A, 25W
Unread 27-01-2011, 14:58
President
360 CPR
Yes it would, but rule <r48> says it must be regulated by an approve power regulator controlled by the cRIO
<R48> All electrical loads (motors, actuators, compressors) must be supplied by an approved power
regulating device (speed controller, relay module, or Digital Sidecar PWM port) that is
controlled by the cRIO-FRC on the ROBOT.
A. Each CIM motor and Fisher-Price motor must be connected to one and only one
approved speed controller. These motors must not be connected to relay modules.
B. Servos must be directly connected to the PWM ports on the Digital Sidecar. They must
not be connected to speed controllers or relay modules.
C. If used, the compressor must be connected to one and only one approved relay module.
D. Each other electrical load (motor or actuator) must be supplied by one and only one
approved speed controller, or one and only one relay module.
Unread 27-01-2011, 15:00
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Originally Posted by Ethan Spitz View Post
$60 for a servo? Wow. Sparkfun and Parallax sell servo's that are compatible with 6V for $13, and I'm sure there are many other sources too.
Unread 27-01-2011, 15:02
President
Yes, but look at the servo's torque. You can't stop it with your hand.
Unread 27-01-2011, 15:09
riptide's Avatar
AKA: Jeff
Comparable servo @ 6V...
http://powerplusproservos.com/
Unread 27-01-2011, 15:10
President
Thanks, but that goes over the 4Watt limit and its digital instead of analog.
Ethan
