Go to Post Many people here in the CD fora know 'someone' on the inside. They aren't out there somewhere, they are here among us and they won't give an inch regarding the clues. It's very cool. - JaneYoung [more]
Unread 26-01-2011, 15:08
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Dashboard Camera Image and Data
This seems to be a common theme so I am going to be utterly blunt and pointed with a few questions to those who have been able to solve these problems that many teams are encountering:
1. With the default dashboard, how would one go about getting a camera image into the appropriate window? Ideally we could get two solution: one for running the camera through the cRIO and another solution for running the camera through the switch.
2. As discussed here and here, the example for displaying various PWM outputs, solinoid outputs (it doesn't work for me with 02011.4 installed), analog outputs, etc. is terribly commented and nearly impossible to figure out. Does anyone have a class or method that would be easy to understand and easy to incorporate into our programs?
Hopefully we can solve the problems and frustrations of many in one afternoon.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 26-01-2011, 16:34
wdell wdell is offline
AKA: William Dell
FRC #3999 (Shadetree Mechanics)
wdell has a spectacular aura aboutwdell has a spectacular aura about
Re: Dashboard Camera Image and Data
I'm not sure why some people are having problems with the code here. To double check, I just uninstalled and reinstalled all the FRC plugins, and it still builds without an error. Have you tried doing the same, removing and reinstalling the plugins?
Also, you could try commenting out the solenoid line that is causing problems, it shouldn't screw anything up. You just won't get any solenoid data on the dashboard.
Unread 26-01-2011, 22:40
frasnow's Avatar
frasnow frasnow is offline
Software
frasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to behold
Actually that doesn't work. You'll get a big ugly looking Dashboard Datatype error on the Dashboard of your classmate. As I said in my post on the other thread, I've tried 4 different PCs and they all have problems with that Solenoid line of code.
Unread 26-01-2011, 22:46
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
You can only see the Axis Camera's feed through the stock dashboard if you connect it directly to the cRIO. As for displaying the outputs, there's some recent threads that should be pretty relevant to your interests.
Unread 27-01-2011, 08:34
AKA: William Dell
Again, I have no idea why you are having problems, mine is up to date and still works.
That being said, try replacing the solenoid line with a constant:
byte thisBytes = 0;
lowDashData.addByte(thisBytes);
Won't tell you what the solenoids are up to, but might allow you to use the rest of the code.
Unread 27-01-2011, 16:41
nima nima is offline
God of code
FRC #0246 (Overclocked)
nima is an unknown quantity at this point
For those of us who are trying to get a direct camera feed, what needs to be done to the dashboard to make this happen?
We have gotten a white screen where the camera image should be although we can connect to the camera via a web browser.
Unread 27-01-2011, 17:12
AKA: William Dell
Nothing has to be done to the dashboard, but the camera has to be set up correctly, and somewhere in your initialization routines you need to do AxisCamera.getInstance() to start it up.
Attaching FIRST's instructions on the proper way to set up the cam.
Unread 29-01-2011, 06:13
The default dashboard and framework dashboard code are written to work with the camera connected to the cRIO. If connected to the dlink and the IP is set to be 10.te.am.xx, you will be able to communicate directly with the camera. This will require modifications to the dashboard.
Greg McKaskle
