Go to Post Oh and don't mind the lightening holes. Thats just how I waste time when I get bored :P - SerpentEagle [more]
Unread 25-01-2011, 16:21
team3607 team3607 is offline
FRC #3607
team3607 is an unknown quantity at this point
Jaguar Light Blinking Yellow
Hi, we are a rookie team this year and are finally starting to get all the electrical components functioning. We have everything hooked up and have the cRIO connected to the driver system. In the tutorials we have looked at, it seems like when on the driver station when we enable the robot, the jaguar light should be a solid yellow. Then as we move the joystick, the light should either be red or green. When we enable the robot, the light continues to blink yellow. We are pretty sure it is connected properly because the light is on but we have been trying to get basic motor controls going with no results. Any help would be greatly appreciated.
Unread 25-01-2011, 16:29
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Jaguar Light Blinking Yellow
jagaur LED status codes:
Normal Operating Conditions
Solid Yellow: Neutral (speed set to 0)
Fast Flashing Green: Forward
Fast Flashing Red: Reverse
Solid Green: Full-speed forward
Solid Red: Full-speed reverse
Fault Conditions
Slow Flashing Yellow: Loss of servo link
Slow Flashing Red: Fault condition
Calibration Conditions
Flashing Red and Green: Calibration mode active
Flashing Red and Yellow: Calibration mode failure
Flashing Green and Yellow: Calibration mode success
Unread 25-01-2011, 16:33
FRC #3607
Thanks for the quick response. So what I got from your response is that the slow flashing yellow that we are having is due to a lack of servo. We have a motor connected but not a servo. I will try that instead. Thank you
Unread 25-01-2011, 16:36
plnyyanks's Avatar
AKA: Phil Lopreiato
they should be able to run with a motor. my thoughts are that the jaguar isn't recognizing whatever is plugged into it. I would make sure that all the wiring checks out. are you using PWM or CAN? my apologies for an unclear wording.
Unread 25-01-2011, 16:37
FRC #3607
Ok. We are using PWM
Unread 25-01-2011, 16:45
The yellow-blinking Jag means that particular PWM output has not been Opened in your code.
What code have you downloaded to the cRIO?
Unread 25-01-2011, 16:53
FRC #3607
I think we have downloaded the basic code that came with the updated labview along with (Robot Main.vi) and also a motor control program we made. But I am not a 100% positive that it is downloaded to the cRIO. I mean the code deploys fine.
Unread 25-01-2011, 17:06
plnyyanks's Avatar
AKA: Phil Lopreiato
In LabVIEW, to download code so it runs natively on the cRIO (as opposed to through a computer), go to the project explorer, expand Build Specifications, right click on FRC Robot Boot Up Deployment and click on Build. After that do the same thing except click on Run as Startup. This will make the code so it runs on the cRIO.
On a different note, open up begin.vi and check the PWM port on the digital sidecar you're using is the same one being opened for the motor
Unread 25-01-2011, 17:24
FRC #3607
Thank you so much guys. We got it working
Unread 26-01-2011, 18:07
Team 1339
Posts: n/a
We are having this same problem, and completed all the steps you suggested to no avail. The PWM's are set to port 1 and 2 in the code and plugged into port 1 and 2 in the sidecar. We ran also 'built' the FRC Robot Boot Up Deployment and Ran it as Startup. The jaguars are still flashing yellow...anything else we can try?
-Team 1339
Unread 26-01-2011, 18:11
Promise that you Enabled it from the Driver Station?
All the status lights on the Digital Sidecar, Power Distribution Panel, and Driver Station are green?
Unread 26-01-2011, 23:13
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
-Team 1339
did you close your variables in the "Finish" and did you remember to put your safety configs for each thing in your begin area with a "merge errors?" Idk if all of those are needed.. but we had the same problem.. I remembered I didn't do either of those and now we have a successful code. Check those, if it works, no questions are needed
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 27-01-2011, 17:35
Team 1339
Posts: n/a
We figured it out guys. thanks for all the help. it was a matter of the 2011 update for labview and then one of the things you suggested
-Team 1339
