Go to Post Teams that take care of the little things often have much less trouble with the big things! - dtengineering [more]
Unread 27-01-2011, 18:37
Rangel's Avatar
Rangel Rangel is online now
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
Reducing the speed of motors
Hello, my team has just got one of our robot chassis built. I then ran tank drive code on the robot and one thing we noticed is that it drove fast. Real Real fast. So what we want to do is cut the speed of the robot in half. How would you give less signal to the pwms.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 27-01-2011, 18:45
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Reducing the speed of motors
If you just want to cut the whole range in half, simply multiply the joystick inputs by .5 before passing them to whichever drive VI you are using.
Unread 27-01-2011, 18:51
Increase the size of your wheel sprockets...
Unread 27-01-2011, 19:19
What you really should do is change the overall gear ratio on your robot so that when you are commanding full voltage to the motors, you get the vehicle top speed you want.
You can do this by increasing the size of the wheel sprockets (as Mark suggested - if you are using drive chains), or by using smaller diameter wheels, or by using a Toughbox gearbox (12.75:1 gearing) instead of the CIMpleBox (4.67:1 gearing) supplied in the KoP.
If you reduce the speed by simply scaling down your joystick outputs in software, you'll wind up with a robot with low acceleration and without much pushing force.
Unread 27-01-2011, 19:22
Rangel's Avatar
John Rangel
Thanks. I guess I forgot to mention that we wanted to go that fast but not all the time. Now we can choose how fast to go.
2014-? Mentor
Unread 27-01-2011, 22:41
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Originally Posted by nckureghian14 View Post
reducing the voltage?
No, that would mean less power. Technically, this never happens anyway, but i don't think we need to get into that.
Yes, this allows you to leave the code alone and still get full power. To cut the speed in half (approximately), the wheel sprockets should be about twice the size. As a bonus, you also get more torque.
EDIT:
OOPS, I missed that. In that case, forget what I said.
Unread 27-01-2011, 23:01
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Ok, so what it sounds like you want to do is use a mapping function to give you more control on the low end with the same maximum signal. This thread talks about various mapping functions, x^3 or variants of it is a common choice.
