Go to Post You are not limited by your resources, but by your imagination. - John Gutmann [more]
  #46   Spotlight this post!
Unread 09-01-2011, 15:36
Erik Huang's Avatar
Erik Huang Erik Huang is offline
Jack of all Trades, Master of None
FRC #0296 (Northern Knights)
Erik Huang is a jewel in the roughErik Huang is a jewel in the roughErik Huang is a jewel in the rough
Re: Minibot
why would you need sensors other than maybe a touch? as soon as it hits the pole, it should go up autonomously, no?
Here ye, here ye! Here cometh the robot!
  #47   Spotlight this post!
Unread 09-01-2011, 16:18
Randy Picolet's Avatar
Randy Picolet Randy Picolet is offline
Caffeine Addic..um..Afficionado
FRC #2159 (RoboPirates)
Randy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud of
Re: Minibot
Can you cite a rule? I couldn't find one or a combination.
See the gossary for ROBOT... ROBOT = HOSTBOT + MINIBOT.
  #48   Spotlight this post!
Unread 09-01-2011, 17:14
Ultramadscienti's Avatar
Ultramadscienti Ultramadscienti is offline
Is experimenting
AKA: Cameron M
FRC #0179 (Children of the Swamp)
Team Role: Student
Ultramadscienti has a spectacular aura aboutUltramadscienti has a spectacular aura about
Send a message via AIM to Ultramadscienti
Re: Minibot
I think I found the rule that would prevent a spring-loaded minibot. I may be interpreting it wrong though. If the list of parts allowed for the minibot says "C. exactly one 12V rechargeable NiMH battery pack identical to those supplied in the FTC kit of parts (PN W739057)" that is exactly one, not up to one. So having a battery on board would defeat the purpose of having a spring-loaded minibot. Just saying.
  #49   Spotlight this post!
Unread 09-01-2011, 18:00
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Minibot
So you mean that just using the battery as extra weight (not electrically connected to anything) prevents me from spring-shooting it up the pole?
I do read the Minobot rule C as "Exactly one" - not zero, not two or more, so I must have that battery as part of the robot. I just have not yet found any rule that requires me to draw any energy from that battery.
  #50   Spotlight this post!
Unread 09-01-2011, 18:18
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Minibot
OK, that being said:
<G19> After DEPLOYMENT, MINIBOTS must remain completely autonomous. Violation: The TOWER on which the MINIBOT is DEPLOYED is diabled. If the MINIBOT is not deployed on a TOWER, then the ALLIANCE’s TOWER upon which the highest RACE SCORE was earned will be discounted.
Interference by an ALLIANCE refers to any action taken by that ALLIANCE that results in disruption of the MINIBOT’s progress. This may include, but is not limited to,
a) throwing a GAME PIECE at the MINIBOT/TOWER,
b) driving a ROBOT or GAME PIECE into the TOWER, or
c) directly contacting the MINIBOT or TOWER.
An example of unsafe operation would be uncontrolled motion that cannot be
stopped by the DRIVERS.
(Emphasis mine)
This may be controversial, but if I launch a minibot mechanically (e.g. with a spring), is that "uncontrolled motion that cannot be stopped by the drivers"? If so, it is "unsafe" and not allowed.
(Yes, I know that even the 'conventional' minibots shown at kickoff couldn't be stopped either).
  #51   Spotlight this post!
Unread 09-01-2011, 18:24
Chris is me's Avatar
AKA: Pinecone
Re: Minibot
(Emphasis mine)
That rules makes every minibot illegal, as a non autonomous minibot is against the rules.
  #52   Spotlight this post!
Unread 09-01-2011, 19:27
Is experimenting
AKA: Cameron M
Team Role: Student
Re: Minibot
I didn't mean that you couldn't make a spring-loaded minibot, I was merely remarking upon the paradox of adding dead weight to something that needs to climb (or launch and reach a specific altitude and hit a target with a specific force) fast.
(>O_____________________________o)> ~ whale hug
  #53   Spotlight this post!
Unread 09-01-2011, 20:16
Re: Minibot
You can also read that rule as you are permitted to have exactly one battery, or, If we use a battery it must be exactly one of this type.
For the record, there are mechanically autonomous things. For example, certain types of clocks, mousetrap cars, Rube Goldberg machines (in general).
I would suggest that any Minibot attached to the pole is not undergoing uncontrolled motion, unless it's going from top to bottom and back again at extremely high speed. The motion is perfectly constrained and all you need is something to stop it.
  #54   Spotlight this post!
Unread 27-01-2011, 19:46
beandip3160's Avatar
beandip3160 beandip3160 is offline
FRC #3160
beandip3160 is on a distinguished road
Re: Minibot
Originally Posted by kfgk14 View Post
Hypothetically, if one wanted to use a spring-loaded fulcrum to launch their minibot up the tower, would that be legal? Would the minibot then be considered a projectile? Does the minibot have to use a motor?
Would this be considered a safety hazard?
Could this (or a variation of this concept) be legal?
The rules say that you cant use stored energy
also the host bot itself may not deploy the minibot
  #55   Spotlight this post!
Unread 27-01-2011, 19:57
pfreivald's Avatar
AKA: Patrick Freivald
Re: Minibot
What?
I'm not sure what you mean by this, but it suddenly has me very worried that I have missed something rather important!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #56   Spotlight this post!
Unread 27-01-2011, 20:01
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: Minibot
Does the entire minibot have to climb the pole or can like half go up and the other half stay at the bottom?
NVM, cant grow bigger than the size limit.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #57   Spotlight this post!
Unread 03-02-2011, 10:04
adam the great's Avatar
adam the great adam the great is offline
Strategy Mentor
AKA: Adam Brewster
FRC #2168 (Aluminum Falcons)
adam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud of
Re: Minibot
Originally Posted by Erik Huang View Post
I believe you can only have 1 minibot.
You CAN have more than one minibot. obviously not on the bot at a time but you can have more than one. It is also to allow teams to lend them to other team for coopertition points.
  #58   Spotlight this post!
Unread 03-02-2011, 11:15
firemaster193's Avatar
firemaster193 firemaster193 is offline
FRC #2130
firemaster193 is an unknown quantity at this point
Re: Minibot
We were thinking the same thing but we found a rule stating that the minibot must have 1 motor we think it means it must use a motor to get up to the top of the tower
  #59   Spotlight this post!
Unread 03-02-2011, 12:54
Re: Minibot
Minibots are not required to have any motors at all.
However, climbing the pole legally without at least one of the Tetrix motors is impossible under <G19>. You are allowed 2 Tetrix motors, and no more, on a minibot.
  #60   Spotlight this post!
Unread 04-02-2011, 10:22
Durham86 Durham86 is offline
FRC #2883
Durham86 is an unknown quantity at this point
Re: Minibot
Here is a short video of our minibot and we would love some positive feedback from anyone that can offer it. http://www.youtube.com/watch?v=HZvXsaTXGfI
Thank you from team 2883 F.R.E.D
