Go to Post ummm who is John V Neun....? - Korbin [more]
Unread 26-01-2011, 16:02
chemipanda chemipanda is offline
Budha
FRC #0240 (TEMPEST)
chemipanda is an unknown quantity at this point
Minibot
We are using the Minibot kit we got from the FIRST Choice program and the shaft collars don't seem to work too well. Any suggestions on something else to use instead of those collars?
Unread 26-01-2011, 16:06
Brandtlamonte Brandtlamonte is offline
FRC #2080
Brandtlamonte is an unknown quantity at this point
Re: Minibot
Chemi, I don't understand what the problem about the collars is, they seem to be working fine for all the teams I've contacted. Are you tightening them around the flat part of the motor axle?
Unread 26-01-2011, 16:16
D.Allred's Avatar
D.Allred D.Allred is online now
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Re: Minibot
There are instruction manuals you can download from the Tetrix site. Here's the link:
http://www.tetrixrobotics.com/Buildi...lt.aspx?aid=80
Unread 26-01-2011, 16:33
Budha
FRC #0240 (TEMPEST)
Re: Minibot
Yes they seem to keep moving when we tighten them as tight as we can get them but they seem to keep moving. I'll get a picture uploaded once I am done at our meeting
Unread 26-01-2011, 17:37
FRC #2080
Re: Minibot
Make sure you zoom in =p
Unread 26-01-2011, 20:29
Mr_D_Mentor's Avatar
Mr_D_Mentor Mr_D_Mentor is offline
AKA: Frank D'Anna
FRC #5856 (The Bullbots)
Mr_D_Mentor is on a distinguished road
Re: Minibot
We had trouble with our first design that depended on driving torque through the set screws. All of our subsequent iterations have a gear bolted to the wheel so the torque goes through the 4 #6 screws.
8th year mentor
Bullbots, First Team #5856
The Nuts & Bolts of Fury, FIRST Team #3525
Team MAX, FIRST Team #1071
Unread 26-01-2011, 21:34
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: Minibot
There are two axle sizes in Tetrix (at least.) Motor axle is bigger than the other one. To accommodate this there are two different axle hubs. You can't put the regular hub on the motor, but the motor hub would go onto the other axles but quite loosely. You might not be able to get the set screw on a motor hub to tighten enough on a regular axle. And if you did, the wheel or gear would be off center.
If you are sure you're using the correct hub and axle combination, take the previous poster's advice and check to see that the set screw is being tightened onto the flattened part of the axle.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 27-01-2011, 09:12
Budha
FRC #0240 (TEMPEST)
Re: Minibot
we had one of our sponsers at our meeting last night so i was unable to get a picture but i have another question. Are we allowed to use aluminum round stock on the minibot?
I will have a for sure picture tonight.
Unread 27-01-2011, 21:10
Budha
FRC #0240 (TEMPEST)
Re: Minibot
Here are the pictures for our minibot. Over night somehow, now the minibot works with no problems.
ID:	9856  Click image for larger version
ID:	9857  Click image for larger version
Unread 27-01-2011, 21:24
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Chickenonastick is on a distinguished road
Re: Minibot
Instead of using the black set screws, you can always use a 1/4 #6 screw. Our team has never trusted those tiny screws.
Unread 27-01-2011, 21:26
Budha
FRC #0240 (TEMPEST)
Re: Minibot
could you be more specific on those screws
