Go to Post It's really quite amazing what people will find time to talk about in the month before kickoff. - Ekcrbe [more]
Unread 27-01-2011, 21:25
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
Re: Will this circuit work?
Thanks agian for the knowledge folks
Here is our updated plan. Lets see if we understood the feedback correctly.
Name:	minibot electrical system.jpg
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
Unread 27-01-2011, 21:33
Electrical Engineer
Rookie Year: 1995
If the devices you are using are in compliance with <R92>, you should be all set. That being said, I'm not sure that they are...
Mike Betts
As easy as 355/113...
Unread 27-01-2011, 22:07
liam.larkin's Avatar
liam.larkin liam.larkin is offline
We will find a way or make one!!
FRC #0272 (Cyber Crusaders)
liam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to behold
That looks good to me.
Switch one is normally open
Switch two is normally closed
I think that will work well. Motors in Parallel??? I mean sure why not harder to physically wire but sure...for this application series will be work just fine
Unread 27-01-2011, 22:29
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
That's not correct at all. Motors in series would get approximately half the voltage and spin half as fast. In a Minibot race you really don't want to do that (for the way up at least).
Unread 27-01-2011, 22:31
Yes the voltage drop across them would be cut in half.....Yes right DUH.....Sometimes I loss my head
Unread 27-01-2011, 22:36
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
If the "shunt fields" are just coils that they manufacture out of the allowed wire, then they should be fine, if they are anything more than that, they might have trouble. That being said, the "shunt fields" aren't really necessary, the minibot should do just fine if it is simply turned off. if this makes it fall too slow, I suggest a loop of lexan for a bumper.
Unread 28-01-2011, 08:20
JJ,
If switch number one is normally opened until you contact the tower and switch number two is normally closed until you reach the top, then this configuration should work. What remains is how to get the minibot down.
For those lurking here, the motors don't contain shunt field coils since these are permanent magnet motors. This is just a drawing.
