Go to Post Why do FIRSTers think we're better? ...because we hold values like honesty, integrity, and intelligence dear... - Redneck [more]
Unread 27-01-2011, 16:30
3p1c w1n 3p1c w1n is offline
FRC #1529
3p1c w1n is an unknown quantity at this point
Problem running code (LabVIEW)
I have created code that should do mecanum drive and have code for 3 LED's using spikes. I'll try to post some print screens when i get a chance. When I go to the robot main.vi and look at the error list, there are no red flags there. I simply click run from the robot main.vi and it says it deploys successfully.
Then I can get a live camera feed from the robot to the driverstation, but i get a ton of repeated error messages. I believe these are the only errors, just repeated very frequently!:
ERROR <Code> -44006 occurred at DriverStationEnhanced IO.lvlib:Access Raw Cypress outputs.vi>>DriverStation.lvlib:Start Communication.vi>>Robot Main.vi
ERROR <Code> -44003 occurred at Camera.lvlib:Issue HTTP Request with Authentication.vi>>Camera.lvlib:Issue Get.vi>>Camera.lvlib:Set Image Appearance Property.vi>>Camera.lvlib:Set Enum Appearance Property.vi>>Camera.lvlib:Set Image Size.vi>>Begin.vi>>Robot Main.vi
ERROR <Code> -44003 occurred at Camera.lvlib:Issue HTTP Request with Authentication.vi>>Camera.lvlib:Read JPG.vi>>Camera.lvlib:Acquire Image.vi
http://www.mediafire.com/file/7cbu4v.../WPI_Error.txt
~Team 1529 Cybercards~
Unread 27-01-2011, 18:19
Re: Problem running code (LabVIEW)
The -44006 probably just means the Cypress I/O card isn't plugged in.
Unread 27-01-2011, 18:40
FRC #1529
What is the Cypress I/O card? Is that one of the ones that goes into the cRIO?
Unread 27-01-2011, 18:50
It's optional for custom buttons and other controls. It connects to the Classmate. It came in a white hard plastic case the size of a double DVD case.
Your team would have gotten it in last year's Kit.
There's nothing wrong with not having it, if you're not using it. We just get a message that it isn't there because the Driver Station looks for it.
Unread 27-01-2011, 21:28
FRC #1529
Thank you for your quick replies. I did get it working. It was a fail on my part. I had not yet re-imaged the cRIO this year. After doing that everything worked just fine.
Thanks!
Unread 27-01-2011, 21:34
I'll have to remember those symptoms...
Thanks
Unread 28-01-2011, 09:33
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
This is good to hear, since I thought we had fixed this error. There shouldn't be an error just because the optional board isn't plugged into the classmate.
Doug Norman
