Go to Post We are customers to FIRST. In that comes expectations. I don't want to hear another, "You should be grateful for everything FIRST does" nonsense when FIRST royally screws up. - MikeDubreuil [more]
Unread 27-01-2011, 21:34
Ted3299 Ted3299 is offline
Team 3299 Programmer
FRC #3299 (Warehouse Crew)
Team Role: Driver
Ted3299 is an unknown quantity at this point
Can I run the robot through labview on my computer im using to program?
Hey there,
I'm still getting use to our robot code and our main guy who does this stuff is gone. I do know a fair amount of Labview programing but I'm confused as to how I plug in joysticks and control the robot while in running the code to the cRIO of my programming computer (a.k.a. no driver station). Our driver station computer isn't currently working
Is there a VI within our basic robot code, which ours is built around the default FIRST code without any deletions of VI's as far as I'm aware, in which there's a working driver station program is basically what I'm asking.
Unread 27-01-2011, 21:40
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Re: Can I run the robot through labview on my computer im using to program?
Part of the installation of the FRC code is the driver station. Make sure you run this when you want to test your robot. It will send the joystick data to the robot once setup.
Mike B
Unread 27-01-2011, 22:14
The official Driver Station program runs on any (Windows XP or 7) computer. Install it using the Driver Station Software Update.
Unread 28-01-2011, 09:39
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
If you're installing the Driver Station on a non-classmate, you will also want to install the FRC 2011 Tools & CompactRIO Drivers from the National Instruments DVD in the kit.
Doug Norman
