Go to Post I could say something technical but I think I will allow myself a moment to pause in the awesomeness... Sweet. - anna~marie [more]
Unread 27-01-2011, 21:59
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
plaction wheels
Hello my team is brand new to using other wheels then the ones provided in the KOP and i was wondering, if we get 6in or 4in plaction wheels from andymark, would the sprocket fit on the wheel without any need to use additional hardware or do we have to buy an adaptor os some sort, it is also a posibility that we could also use a direct drive with them, we are also using the kop frame. If you have any comments good or bad please post.
Unread 27-01-2011, 22:13
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Re: plaction wheels
Yes, they will work fine.
You will need spacers. It may be easier for your team to machine its own, though.
For future reference, look at the bolt circles of the wheel, sprocket, and spacer to see if they will match up. The ones from the KOP use 1.875in bolt circles, as do those spacers and all of AM's Plaction wheels.
Unread 27-01-2011, 22:23
AKA: Garty
Re: plaction wheels
well this was the part we couldnt understand. so say we use the plaction wheel, we put a spacer then the sprocket on the wheel, do we have to change the way the the double sprocket on the cimple gearbox is do we have to cut down a spacer and add to the other?
Unread 28-01-2011, 00:53
AKA: Logan
Re: plaction wheels
I am not sure if I understand the last part of your question... do you think you can clarify it a bit?
The spacer is only a quarter inch thick. It is not designed to be cut down the middle. You will need to have one spacer per side if you want the wheel to have two sprockets.
Are you using four wheels on your drive train?
Unread 28-01-2011, 06:52
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: plaction wheels
You only need the spacer if you are using 22 tooth Sprocket with 35 chain or 32 tooth sprocket with 25 chain. Otherwise i don't believe you will need the spacer.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
