Go to Post It's what this is all about. Making dreams happen. - Astronouth7303 [more]
Unread 28-01-2011, 08:17
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
CANJaguar.java won't compile
I downloaded the CANJaguar example that included the source code from First Forge (rev. 50, created on 02/18/2010 4:46 AM), but when I tried to run it CANJaguar.java gave me this error:
edu.wpi.first.addons.CANJaguar is not abstract and does not override abstract method disable() in edu.wpi.first.wpilibj.SpeedController
public class CANJaguar implements JaguarCANProtocol, SpeedController {
It turns out CANJaguar doesn't implement disable() or set(double speed, byte syncGroup) from SpeedController, but it does have get() and set(double speed). Does anyone else have this problem? I figured I could just add those in as empty methods to get it to compile but I didn't know if there was a bigger problem. If it's as simple as adding in those methods, could someone just share the with me so I can paste them in?
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 28-01-2011, 08:28
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
Re: CANJaguar.java won't compile
You don't need to download the CANJaguar library anymore, it's included in the WPILibJ. Go to firstforge.wpi.edu to get the latest updates. Unfortunately, the automatic updates from last year aren't up to date with the 2011 release, so you need to get them.
Unread 28-01-2011, 10:11
That was true for a few days after kickoff, but not anymore. 2 days ago I updated a computer that hadn't been used since last year, and netbeans notified me of the update automatically. If you installed the .nbm files manually without setting up the update location, they you will also have to manually update (or better yet, set up the update location).
