Go to Post Robotics for me though really is hard to beat. Though tiring and exhausting, the memories you build are priceless. - ShadowKnight [more]
Unread 23-02-2010, 21:11
ahudson ahudson is offline
FRC #3179
ahudson is infamous around these parts
HELP
We have been reading and trying to follow all the posts about wiring solenoid valve to cRio. We have gotten a little farther, but still do not know how to wire the valve to the breakout. We need details. What connectors do we use from the KoP's. We are a rookie team and basically only have what is in the KoPs.
Unread 23-02-2010, 21:35
DonRotolo's Avatar
Back to humble
FRC #0832
Re: HELP
OK, the solenoid valves have two connections at each end - either wires or pins, right? Those two wires or pins need to somehow make it to the Solenoid (or Pneumatic) Breakout. The Pneumatic breakout is a little circuit board in a blue plastic cover, which is connected to the cRio solenoid module (the one with the 8 green LEDs in 2 rows of four on top). That cRio module must be plugged into slot 8 of the cRio (furthest from the power end of the cRio).
To connect those two wires or pins, the kit had a couple of grey cables, each which had two tiny red and white wires inside, and with little black connectors at each end. If the solenoid valve has "pins" then this will plug right in. The other end plugs right into that Pneumatic breakout, it's pretty plain once you see it.
Of course, some programming is needed, and the Pneumatic breakout needs power from the power distribution board (at least 20 ga wire, 20A breaker)
First, look in the Control System Manual that's on the FIRST site to learn more about the Pneumatic Breakout. The check the pneumatics manual, and section 8 of the rules.
So basically: 2 wires from solenoid valve to 2 pin connector on Pneumatic breakout. If your valve has 2 solenoids (one on each end), they both need their own wires and connections (and take up 2, two pin spaces on the Pneumatic breakout.
OK?
Unread 23-02-2010, 21:41
FRC #3179
Re: HELP
Can it go to a sidecar or does it have to go into the cRio
Unread 23-02-2010, 21:48
DonRotolo's Avatar
Back to humble
FRC #0832
Re: HELP
See anything saying "digital sidecar" up there? No? There's your answer.
Unread 28-01-2011, 09:59
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
Re: HELP
Hey Don..that was rather terse. Great example of gracious professionalism. Thanks!
Unread 28-01-2011, 10:10
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Re: HELP
An extremely valuble pneumatics resource is team 358's site here. They have guides for both assembling pneumatics on the robot and for programming. As far as wiring goes, Don hit the nail on the head earlier.
Good Luck!!!
-Alex
2010 Washington DC Regional: Engineering Excellence Award
HELP!!!! we need help w/ compressors/pneumatics for teleop/autonomous in LABVIEW rokenboker NI LabVIEW 9 05-02-2010 17:10
Grab Frame - Help Help Help... nmihailidis Programming 2 04-03-2007 14:44
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
