Go to Post Using a mouse is so 20th century! - Tom Bottiglieri [more]
Unread 28-01-2011, 10:10
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
pic: What is this?
Unread 28-01-2011, 10:11
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: What is this?
Is there any bearing material between the pieces of 80/20? Without that I foresee a lot of mechanical inefficiency in the system. Other than that it looks like you are doing a good job.
Mentor 2415
Unread 28-01-2011, 10:12
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
An elevator made out of 80/20 and #25 run inside the 80/20 to raise/lower it?
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 28-01-2011, 14:47
Mr_I's Avatar
YES! We discovered that #35 chain fits almost perfectly between adjacent pieces of 8020. Add to that the fact that the steel-to-aluminum friction is very low, and you've got a very good thing.
We mounted two verticle pieces of 8020 to the drive train frame, and ran the chain down the slot to a "elevator car" that rides on two pieces of 8020 about 12" long. (There's about 1/16" gap between the car and the rails, so there's little side-to-side drag. ) The car is attached to the chain at the top and bottom, and the chain loops out the bottom via sprockets back to the top. Add a Barbie to drive the sprocket, and we've got a low friction high strength elevator!
"It's NOT Just A Robot Thing!"
Unread 28-01-2011, 17:53
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
Were thinking of doing something extremely similar to this. As this is only are 2nd year would you mind answering a few questions.
What size/type 8020 did you use?
How do you mount the sprockets to the end of the 8020?
Thanks.
Unread 28-01-2011, 23:25
Mr_I's Avatar
Standard 1" x 1"; if you need the exact part number I can dig it up.
We bolted a piece of 3/8" lexan to the end of each 8020. The shaft for the sprocket goes through bearings which are mounted to the lexan. We used T-bolts to attach the lexan to the 8020, so we could slide the lexan (and therefore the shaft) to take up any chain slack.
Unread 29-01-2011, 09:38
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Interesting. Looks like things are coming along.
How 'bout a quick vacuum of the robot frame?
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 30-01-2011, 05:00
Hellfeier675's Avatar
Hellfeier675 Hellfeier675 is offline
FRC #0675 (Tech High Robotics Syndicate)
Hellfeier675 is an unknown quantity at this point
Good idea! My only warning is that we used 80/20 in the past to build a forklift (2008) and unless everything is 100% lined up, you're going to start building up a lot of friction. Given that we had quite a bit more on the end of the forklift though which contributed to the problem, I'd still watch out for friction, it's a killer.
-"Guys it's so inconvenient, Delphi is down at 3 am.... Hey I was bored last night!"
Unread 30-01-2011, 07:38
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Your saving grace here is that the aluminum used for in 8020 is anodized. The anodized layer is very hard and wear resistant. Without this layer the aluminum would quickly gall and cause an immense amount of friction. I would definitely keep those slots greased or oiled in case the anodized layer starts to scrape off!
Unread 30-01-2011, 08:58
AKA: Chad
Another question. Do you have a chain on each side of the lift, and if so are both sides powered or does one side just free slide?
Unread 30-01-2011, 12:37
LondonBoy29's Avatar
LondonBoy29 LondonBoy29 is offline
A Man 3000 Miles away from his team
FRC #1884
LondonBoy29 is on a distinguished road
What motor are you planning to use. My team is planning to use either a fisher price or window for our motor, and we can't decide.
