Go to Post Now please, go have some meaningful discussions that will inspire us all. - Ken Leung [more]
Unread 24-01-2011, 19:01
ahudson ahudson is offline
FRC #3179
ahudson is infamous around these parts
pneumatic valves
Is there a valve that will allow the cylinder to stop at any point of the stroke? Or should this all be done in programming?
Andrea Hudson
Unread 26-01-2011, 15:29
keericks's Avatar
keericks keericks is offline
AKA: Kent
FRC #1671 (Buchanan Bird Brains)
keericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of light
Re: pneumatic valves
The Bimba pistons can be obtained with a magnetic sensor to allow for this.
Unread 26-01-2011, 15:41
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
It's usually not something you'd ask pneumatic cylinders to do, however. The sensor will tell you when the piston passes a certain point in its travels but it's unlikely you'd be able to come up with an active system to KEEP it there. Since air is compressable, most people think of pneumatic cylinders as binary devices, they are either extended or they aren't.
Unread 26-01-2011, 15:47
keericks's Avatar
AKA: Kent
Good point Dale ... I misread the OP and missed the "stop" portion. Thanks for the clarification.
Unread 26-01-2011, 15:50
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
It is difficult to stop a cylinder in mid-stroke. It can be done but I wouldn't recommend it to a FIRST team.
If you want to have multiple positions it is best to use multiple cylinders.
Unread 27-01-2011, 00:05
Astarties's Avatar
Astarties Astarties is offline
Evil Robot Overlord
FRC #2057 (AV Cyber Bulls)
Astarties is on a distinguished road
Agreed, I would use multiple pistons. That shouldn't be an issue this year because of the unlimited number of air tanks.
"Stand tall and shake the heavens!"
"Never tell people how to do things. Tell them what to do, and they will surprise you with their ingenuity." - General George Smith Patton, Jr.
By the prickling of my thumbs, something wicked, this way comes. Open Locks, whoever knocks!
"Never hold discussions with the monkey when the organ grinder is in the room."- Winston Churchill
Unread 27-01-2011, 00:19
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
We've done this once. On our 2005 robot Sidewinder on our arm. We used a special valve. A 3 position, center closed valve. Something like an SY3340 SMC Valve.
http://www.smcusa.com/sections/first/SY3000valves.pdf
When you energize the coil on the valve the valve will extend the air cylinder, when you take away the power from the valve, the air cylinder with stop in mid-position. It's not going to be ACCURATE by no means, but it does allow for mid-stroke air cylinders. Of course if you energize the retract side of the valve, it starts to retract the air cylinder and will stop on the way down too.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 27-01-2011, 20:02
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
You can also do it with 2 valves. Use one for direction, the other to open/close the exhaust from the 'direction' valve. We used this with our 'tetra' arm, worked well.
Here is an example of how to plumb it: http://www.chiefdelphi.com/forums/sh...01&postcount=5
And a whitepaper: http://www.chiefdelphi.com/media/papers/1476
Unread 27-01-2011, 21:51
Except for this:
<R74> Each commanded motion of a pneumatic cylinder or rotary actuator must be accomplished via the flow of compressed air through only one approved pneumatic valve. Plumbing the outputs from multiple valves together into the same input on a pneumatic cylinder is prohibited.
Unread 27-01-2011, 22:03
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
Team Role: Driver
bobosalad is an unknown quantity at this point
it looks like they dont want double imput. well that that would be connected to the output, so it would be legal?
Spartans, Prepare for GLORY!
Unread 27-01-2011, 22:13
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
They do make multi-stroke cylinders as well, which are accurate AND simple.
http://www.bimba.com/pdf/catalogs/FL_OriginalLine.pdf
Go to page 67 for the three position cylinders, I'm sure you could find cylinders with more positions from other suppliers if you looked hard enough.
Unread 28-01-2011, 10:39
Nemisis's Avatar
Nemisis Nemisis is offline
Frame/Body/Motors
FRC #2389 (S.T.O.R.M.)
Nemisis will become famous soon enough
Hey everyone, I know this has more than likely been already covered but our team has read the rules and read the rules but we still cannot find exactly how many canisters, (Used for Volume) we are allowed to use?? Can anyone help? Please? Thank You!
RHS Senior 2011
Unread 28-01-2011, 10:45
implosionprez's Avatar
implosionprez implosionprez is offline
AKA: Ty
FRC #2484 (Team Implosion)
implosionprez is an unknown quantity at this point
There is no limit as to how many pneumatic storage tanks you can use this year.
From the FRC Forums:
Team Update #2 makes doesn't give a limit to the number of pneumatic storage tanks a team can use. This makes it sound like teams can use an unlimited number of storage tanks on the hostbot. Is this true?
GDC: Correct, there is no explicit limit on volume of stored air permitted on the ROBOT.
Unread 28-01-2011, 10:48
Nemisis's Avatar
Frame/Body/Motors
hey thanks for the reply! thats exactly what our team thinks about it! but we're not exactly for sure ya know?
RHS Senior 2011
