Go to Post I like my eyeballs where they are ::safety:: - ,4lex S. [more]
Unread 28-01-2011, 11:42
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Control of Decorations (Led displays)
Al - Thanks for the clarification. I agree the current requirement will not even be close to exceeding the limitations of the spike relay, ours are about 30 mA max.
I may be "lawyering" these rules too much, but I am trying to make sure that I understand them fully. The document you specified was the one I was discussing as well. That document only specifies controlling 2 devices if they are solenoid valves. Obviously that document is not FIRST official but is just a reference.
So you are saying that the "single relay module" from the rules is not referring to the spike relay but is instead referencing the solenoid breakout, as seen here? I don't think this is true, and I think that I am misreading your post (although you did say "Crio solenoid/relay module").
So the question remains, are LED's (and their associated circuitry) considered an actuator? If so, then only one module may be controlled through a spike relay. If not, then there are no rule limitations (in this context, obviously practicality,safety and electrical limits apply) to how many be controlled by one relay.
I feel that I am beating this to death, and I will defer to your wisdom as an outstanding Robot Inspector.
