Go to Post Logic has no place here whatsoever. - ThamiorLianodel [more]
Unread 28-01-2011, 13:38
Re: Wireless Networking Problems
Originally Posted by jtechau View Post
So how does it choose between the LAN adapter and the wireless adapter? Or do we have to manually set up the network configuration?
This year's Driver Station allows you to manually select the NIC used.
It's on the Setup tab.
Outside that, the DS will continue to reset the last NIC specified, so if you went and did another one by hand, then when you restarted the DS application you could end up with two set to the same IP address.
