Go to Post Put on shows. Start new teams, FRC, FVC, or FLL. It doesn't matter. But I know that being on the robotics team has given me some of the best memories of my life, and I wouldn't want anybody else to miss out on that. - irishninja [more]
Unread 21-01-2011, 20:38
Twisted eric's Avatar
Twisted eric Twisted eric is offline
FRC #0581
Twisted eric is an unknown quantity at this point
A Question about rule R11
OK being the end of the 2nd week my team still has no design for the robot some are saying elevator and some are saying just the arm and the last third are saying both.
But i brought up a good question on rule R11
about not breaking the 84' diameter mark now is that from the middle of the robot or is that from the bumpers because I measured it out and from the center it only gives us about 1.5 feet. Now am I wrong and is it from the bumpers?
Thanks to all people who help
and is any one actually going to use an elevator? (because i know every one is going to use an arm)
Unread 21-01-2011, 20:48
DonRotolo's Avatar
Back to humble
FRC #0832
Re: A Question about rule R11
It's all in there.
Anyway: Your robot, which does not include bumpers, must at all times fit within an 84 inch diameter right cylinder of infinite height.
Unread 21-01-2011, 20:56
FRC #0581
Sorry if I'm just blind i don't see it and neither douse my team. >< this is annoying.
can you tell me which section its in sorry
Unread 21-01-2011, 22:01
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
From the top:
You need to have this page on your favorites/bookmark list. This is where the information lives.
Second, Look in the complete manual OR the section 4 Robot descriptions. Use the search function of Acrobat to find <R11> or just scroll down a bit until you get there.
Third, Read for a while.
Fourth, come back here if you're still having problems understanding the rules as they are written.
Fifth, read the rest of the document, fortified with whatever beverage(s) will lubricate the process. In N.E. the choice is hot chocolate - don't spill any on the keyboard! I've heard good things about the Dew too.
Oh, and I can totally sympathize with your team's design difficulties. It even has a name- Paralysis by Analysis. Coming into contact with it firsthand is a valuable experience for your team members. Even if all your team does is build each of their ideas and they only get as far as the practice fields, they can still have fun, be inspired, and learn a thing or five about engineering.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 21-01-2011, 22:39
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
I'm pretty sure that the rule was your robot has to fit into an invisible 84" diameter cylinder at all times, no matter where its measured from.
But do read the manual, I tend to be wrong a lot.
Unread 21-01-2011, 22:54
FRC #2170
The trickiest thing about that 84" cylinder is that it can shift around as the parts of the robot change their positions. For instance, if your manipulator arm moves to one side and reaches the limiting distance, it could move the same distance to the other side of the robot. The distance between the two points reached can be farther apart than the magical 84" distance because the cylinder limit retreated from the first point as soon as the manipulator moved.
If you want to talk geometrically, consider the projection of your robot, manipulators extended, onto the plane of the playing surface. After doing so, a circle of diameter 84" must be able to contain all the projected lines with none of them crossing its circumference.
Unread 21-01-2011, 23:25
FRC #0581
oh i believe i understand now thanks every one
Unread 28-01-2011, 15:16
WireFreaks2156's Avatar
WireFreaks2156 WireFreaks2156 is offline
.Keep it simple.
AKA: Jessica Hageman
FRC #2156 (WireFreaks)
Team Role: Team Spirit / Cheering
WireFreaks2156 is a jewel in the roughWireFreaks2156 is a jewel in the roughWireFreaks2156 is a jewel in the rough
Rule <r11> sayd that the cylinder is 60'' in diameter while playing and before game starts it has to fit in a 28''x38'' rectangle with a 60'' height
Unread 28-01-2011, 15:18
GaryVoshol's Avatar
Cogito ergo arbitro
You aren't still reading the original version of the rules, are you? There have been 5 revisions already - labelled Rev-A, B, C, D, E - and another may come out today.
The 60" cylinder has been corrected to 84".
(since 2004)
