Go to Post Sometimes it's not what you know going into a battle, but who you know. - Elgin Clock [more]
Unread 19-01-2011, 02:44
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Pneumatic Air Tanks
Originally Posted by Matt C View Post
I KNOW at least one team is going to have a crazy pneumatics setup this year.
That just might be us~
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 19-01-2011, 07:57
As a reminder to everyone...
<R69> Compressed air for the pneumatic system on the ROBOT must be provided by one and only one compressor. This compressor may be either the compressor from the KOP, or an equivalent compressor that does not exceed any of the KOP compressor performance specifications (specifically: nominal 12v, 1.03 cfm flow rate, 120psi maximum working pressure). Compressed air shall not come from any other source. Off-board compressors must be controlled and powered by the ROBOT.
Emphasis mine.
Unread 28-01-2011, 10:59
Nemisis's Avatar
Nemisis Nemisis is offline
Frame/Body/Motors
FRC #2389 (S.T.O.R.M.)
Nemisis will become famous soon enough
Actually... I'm not going to say read the manual.
I'm going to say, Watch Q&A, because someone asked there already due to it not being specified in the Manual.
Do we have an update on this yet? Did the 2nd update specify how many tanks we can have on board now?
RHS Senior 2011
Unread 28-01-2011, 12:53
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
You might read the Team Updates and determine the answer yourself, rather than waiting for someone else to read them and feed the answer to you. Really, everyone should read the Manual and the rules updates. It is worth the effort.
-dave
Unread 28-01-2011, 12:55
The updates didn't say it quite clearly enough for some folks.
Q&A said, quite clearly, that there is no explicit limit. In other words, as long as all your air tanks fit in the box, meet the cost and weight constraints, and are correctly connected (the ones you aren't using as ballast), you can use as many as you want. Oh, and make sure you satisfy the pressure ratings, too.
http://forums.usfirst.org/showthread.php?t=16408
Unread 28-01-2011, 15:33
Dave is suggesting you go to R66 par. J & K.
