Go to Post (Don't you hate it...) "when... no more buttons can fit onto your clothing at competitions?" - mcb [more]
Unread 28-01-2011, 18:04
Re: two soleniods controlled by one relay
Links to the IFI documents can be found on the First KOP page or by going directly to the IFI (Innovation First, Inc.) website.
Unread 29-01-2011, 06:18
johncap100 johncap100 is offline
FTC #0658
johncap100 is an unknown quantity at this point
wow lots of good discussion, I did mean the solenoid breakout, i simply used the word relay because that is what is printed on the side of the breakout. I did get it working. As it turned out i had a single space on the ref name, so the second solenoid was not being read.
I do understand now that the spike is called a relay and the breakout is not called a relay. But understand my confusion when right on the breakout it is labeled a relay.
thanks again for all the discussion
Unread 29-01-2011, 09:47
Glad you are in business. Good Luck.
