Go to Post I've found that being outraged on behalf of others is often a misuse of energy. - Taylor [more]
Unread 28-01-2011, 18:39
jhellr13 jhellr13 is offline
FRC #4272
jhellr13 is an unknown quantity at this point
Minibot Falling Solutions
There might be multiple threads of this question, but i would like to make a general one with multiple ideas.
My team today has built a minibot prototype, and it works pretty good. We are running into a problem when the minibot slides down from the top. The minibot moves great upward, but drops like a stone.
What are some of your team's ideas on keeping the minibot's downward movement controlled and safe to avoid a hard crash?
Unread 28-01-2011, 18:46
nitneylion452's Avatar
AKA: Joe Lee
Re: Minibot Falling Solutions
We were hoping that the motor, being geared, would provide enough resistance to falling. Our main concern, though, is getting the motors to stop because I was trying to see how much torque the motors provided by trying to stop the wheel from spinning. Good news: plenty of torque. Bad news: motor began to smoke after a few seconds.
ttldomination's Avatar
Sunny
Try putting memory foam at the bottom of your bot. A nice soft landing.
1648: 2013-2014
5283: 2015
Unread 28-01-2011, 18:57
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Originally Posted by jamie_1930 View Post
We're thinking of using a ratchet to make sure the robot stays at the top when it get's there and then use a pole to get it down after the match.
Start thinking some more, this is illegal per Team Update #6.
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Memory foam isn't on the approved materials list. Your only potential options would be rubber bands, surgical tubing, non-slip pad, or hook and loop fastener.
Unread 28-01-2011, 19:00
FRC #4272
Yeah, we have a 1 to 2 gear ratio, and it just falls ways too fast.
Our motor as well has begun to smoke
Memory foam sounds like a great idea, but does it effect the weight strongly?
Unread 28-01-2011, 19:02
Double posting so I don't have to edit a post...
Are these minibots falling/dropping just from the weight of the minibot backdriving the motors? I'll admit I haven't looked to see how fast they backdrive, but falling like a stone doesn't seem likely... If this is the case, however, I vote rigging up a light switch to switch the positive lead on one or both motors from the positive battery lead to the motor's negative lead. Instant regen braking and all that.
Unread 28-01-2011, 19:06
FRC #4272
We are planning on using a switch to start the climb, and a switch to make the minibot stop at the top, and then move down slowly. I'm sorry "dropping like a stone" is somewhat an exaggeration, but it just doesn't slide down at a slow, safe pace.
What do you think now that memory foam is not allowed?
Unread 28-01-2011, 19:17
Memory foam was never on the allowed materials list for the Minibot. However, it's not on the disallowed materials list for the Hostbot.
I had an idea: If the robot's arm just so happened to be up at the end of the match, just so happened to be about 10' tall, and just so happened to have a device at a shoulder joint that would allow any claws to be operated by hand without robot power being turned on, I don't think the refs can use the "special equipment" rule to disallow that being used to bring the Minibot down. It's part of the Robot, after all...
Unread 28-01-2011, 19:21
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
http://www.chiefdelphi.com/forums/sh...inibot+warning
It explains a solution for prototyping, but not for the real bot. Surgical tubing or something on the bottom might help.
Unread 28-01-2011, 19:25
FRC #4272
I know it was never allowed. And your idea sounds very possible and smart. Our team is deploying our minibot by using drawer glides attached to a scissor type of device. I thought with your idea, if it would a good idea to put the memory foam on the end of the scissor where the minibot would deploy onto the pole. Now my concern is the hostbot is allowed to have a part of itself on the pole platforms when the minibot is deployed onto the pole
Unread 28-01-2011, 19:40
klmx30302's Avatar
klmx30302 klmx30302 is offline
Is ready for MAYHEM In Merrimack!
AKA: Kevin McCarthy
FRC #0166 (Chop Shop)
klmx30302 is a jewel in the roughklmx30302 is a jewel in the roughklmx30302 is a jewel in the rough
c/p from team update #6
<G59> TEAMS must retrieve MINIBOTS from the TOWER quickly and safely without special equipment and while standing on the floor after each MATCH. Violation: The FIELD crew will retrieve the MINIBOT if the TEAM does not. A second violation may result in a YELLOW CARD.
so you kind of need the minibot to come back down now or you need some really tall team members.
Unofficial Team 166 Videographer
Our team motto...
"THINK!, There must be a harder way!"
Unread 28-01-2011, 19:47
AKA: Joe Lee
What if we buy a really long overcoat and have 3 people stand on each other's shoulders, then they wear the coat. It would appear that it is one person, but it's not.
Unread 28-01-2011, 19:48
FRC #4272
Yes, but does the hostbot need to be completely off the pole tower before deploying the minibot?
Unread 28-01-2011, 19:53
FRC #4272
Wrap the coat in tin foil to give that metallic look too
