Go to Post No amount of sleep beforehand will make up or prepare you for the lack of sleep you will receive during build season. - Dan Petrovic [more]
View Poll Results: What Program Would You Like to See?
RoboEmu for Linux 1 3.13%
RoboGUI for Linux 1 3.13%
Computerized Robot Control 19 59.38%
YADP 3 9.38%
Other 8 25.00%
Voters: 32. You may not vote on this poll
Unread 25-10-2002, 20:47
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
What program should I write?
Well, nobody has complained about any errors in RoboEmu 1.06, so I'm going to assume it works for everyone (let me know if I'm wrong!). Therefore, I know have a lot of free time, so I want to start another project that people think might be helpful.
Anyway, here's a little explanation on each of the choices:
  • RoboEmu for Linux--a linux port of my PBASIC emulator
  • RoboGUI for Linux -- a linux port of my program creator
  • Computerized Robot Control -- ability to control the robot using a laptop, etc. Seethis post and the replies for more info.
  • YADP -- yet another dashboard program for Windows (I already wrote one for Linux).
  • Other -- let me know if you have any other ideas.
I'm open to just about any project, whether its a handful of lines of code or mult-thousands of lines (like RoboEmu and RoboGUI), I'm willing to do it if people have the desire for it. Also, it doesn't have to be something to help programmers. If you have ideas for helping the electrical, pneumatics, mechanical, animation, chairman's, etc people, I'd be willing to do that too.
--Rob
P.S. If you haven't checked out RoboEmu, RoboGUI, or gDash (Linux dashboard viewer), they're available at http://FIRSTprograms.tripod.com/Programs.htm
Unread 27-10-2002, 16:42
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
How about a Basic Stamp II Editor/Download Controller that runs native on a Mac under OS X?
I've tried a the expected kludge answers (i.e. stampw.exe running on Virtual PC v5.0 under OS X 10.2, with a Keyspan USB-serial adapter with din-9 to DB-9 cable, etc.) with frustrating results. Anyone up for writing a better solution (and don't say "get a PC" - I'd rather shove a stick in my eye)?
- dave
Unread 27-10-2002, 18:02
Running native under OS X? That shouldn't be too bad. After all, it's just BSD. Hmmm.... maybe for MacOS 8, as that's what I have on my OLD desktop (read: 33Mhz). Excellent suggestion, dlavery.
Unread 29-10-2002, 12:26
ECarlson's Avatar
ECarlson ECarlson is offline
AKA: Eric Carlson
ECarlson has a spectacular aura aboutECarlson has a spectacular aura about
I sent you an e-mail with enough suggestions for updating RoboEmu 1.06 to keep you busy for at least an hour.
- Eric
www.InvisibleRobot.com Updated: August 24, 2008
Over 28,000 FRC & FTC Photos , Team 116 OI adapter board info
Unread 29-10-2002, 15:24
An hour? At LEAST! They're good suggestions, though, and I'll probably try to incorporate as many of them as I can without gutting the whole program. I especially liked the idea of indicator bars for the PWMs, and lights for the relays. I'll probabbly just write a few more ActiveX controls to handle all the messy drawing stuff. The Paused PWMs staying at 127 is a know issue, but I have absolutely no idea why it does this. My only guess is that it has something to do with my thread syncronization(sp?) stuff. Anyway, I've got an MIT application to finish by Thurs, but after that I'll get back to work on some of this stuff.
As for the computerized Robot Control, codenamed RoboCon, it's coming along. As soon as I get an OI from the school, I'll begin my initial beta tests. Yes, that does mean I have the code mostly done. Again, look for an initial and very buggy release (like the first releasees of RoboEmu) by early next week.
As for a Mac OS X PBASIC IDE, I'm currently planning on writing a Linux version using gtk+, which should also compile on OS X, but I really am not that familiar with MacOS higher than 8.1. From what I've heard, though, I shouldn't even need to modify the code at all. Anyone want to confirm/disprove this?
--Rob
Unread 29-10-2002, 15:57
ECarlson's Avatar
AKA: Eric Carlson
Thanks for the update. Please add the LED outputs for each joystick.
I said "an hour" since you seem to be a very fast programmer. It's amazine that you can get all these programs done so quickly.
Good luck with MIT.
- Eric
Unread 29-10-2002, 22:31
For each joystick?!?!?!?!?
Do you mean relay? I hope so, 'cause otherwise I'm completely lost and confused. Maybe those seven cans of Coke this afternoon wasn't such a good idea....
Unread 29-10-2002, 22:46
ECarlson's Avatar
AKA: Eric Carlson
Robot feedback LED's on joystick ports 1 & 3, pins 5, 8, 9, 15, Variables Out8-Out15.
- Eric
Unread 31-10-2002, 09:16
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
What about something that allows you to program from a USB port? Seeing as more and more laptops are going "legacy-free", it's hard to find a new laptop suitable for programming.
Jeff Waegelin
Unread 31-10-2002, 11:18
ECarlson's Avatar
AKA: Eric Carlson
Your team gets new laptops!? We have an old Pentium-100 with a 640x480 screen running Windows 95. It doesn't even have USB. It has to be plugged in because the battery is dead. And sometimes it crashes for no reason.
PS: For you lucky teams with new laptops, I think you can get a PCMCIA to serial or a USB to serial adapter.
- Eric
Unread 31-10-2002, 15:39
SlamminSammy's Avatar
SlamminSammy SlamminSammy is offline
SlamminSammy is on a distinguished road
Send a message via AIM to SlamminSammy
Other teams have their own laptops for programming? We have one for web-design and we technical people have to buy/use our own (actually, Rob just "borrowed" his laptop from another high school--that was a few years ago and we're not sure if they're missing it yet).
The opinions stated above are not necessarily those expressed by the FIRST Robotics Program, its participating teams, or any other individual or organization.
Unread 31-10-2002, 15:45
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
Macs
How about a RoboGUI and RoboEMU for Mac OS9. Maybe even that DashboardSpec thing for mac.
Apple gave our county a grant and we all get shiny new iBooks.
Too bad there isn't a useful program on them, no office, no .avi player. Also they are locked down so we can't load anything on them, no freeware, no Parallax, etc.
Yes it would be great if we could use these for programming, but common nonsense has prevailed again
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 31-10-2002, 16:34
I gave that one back and you know it! Sam's point still stands though: I have to use my own.
OK, back to my actual responses:
Unfortunately, the Stamp processor doesn't understand USB electrical/signaling protocols, so you'd need to convert it to RS-232 anyway.
OS 9 would be almost impossible as I don't have any OS 9 computers. If I ever get around to doing a Linux port, it should compile under OS X, as well. Speaking of laptops, I'd be perfectly willing to try my hand at an OS 9 version if someone wants to donate a Mac laptop to me....
Currently, I'm working on RoboCon, the computerized robot control, but as soon as that's done, I'm going to port as much of my stuff to Linux as I can.
In any event, RoboEmu 1.07 is done, so check it out if you have the time.
--Rob
Unread 31-10-2002, 19:58
El Jefe de 148
Actually, the laptop I use is my own personal machine. I have a nice, new laptop that I bought, and it doesn't have serial. Right now, we're stuck with an old NEC Pentium 90 that has no CD or battery. It's also Win95, but with an 800x600 screen.
Jeff Waegelin
Unread 31-10-2002, 23:48
MacZealot MacZealot is offline
MacZealot is an unknown quantity at this point
Send a message via AIM to MacZealot
Gimme a few weeks and I might be able to port your unix programs to OS X (and port it to cocoa while I'm at it)
OS 9 programming is worthless. That OS is dead to developers anyway.
AIM: Joe7464685192 | Email Me! Visit my site!
Uh I'm STILL not in Las vegas GRRRR!! I dun think it'll happen till june and This shoulda happened a freaking year ago
2-week FIRST summer program @ WPI ColleenShaver General Forum 20 31-05-2009 03:02
read and write command rosebud Programming 3 26-03-2003 19:44
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
Credits for FIRST program. archiver 2000 6 24-06-2002 00:16
