Go to Post I was cheering like mad during the last match on Einstein - I think the rest of my team thought I was crazy...or crazier than they thought I was before! - Sean Schuff [more]
Unread 28-01-2011, 20:35
Cody Trey's Avatar
Cody Trey Cody Trey is offline
Programing = hard + fun
FRC #2582 (Panther Bots)
Cody Trey is an unknown quantity at this point
Send a message via Yahoo to Cody Trey
Question Jaguar will not go backwards
Our bot is running a four motor mechanum drive
all of our motors will go forward, but when we try to go back, one or two of them will not turn, any ideas?
ask any questions you think may be relivant
Love, Peace, and Robot Grease
Unread 28-01-2011, 20:44
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Re: Jaguar will not go backwards
Are these tan Jags by any chance? Failure in one direction only is a know failure mode of the Tan Jags.
Unread 28-01-2011, 20:46
Cody Trey's Avatar
they are tan, is there any way to fix this problem?
Unread 28-01-2011, 21:00
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
If it is a Jaguar hardware failure there is no competition legal way to repair it. Check and make sure that the lights on the Jaguars affected are changing the way you expect when powering in the direction that doesn't work. If the Jaguar light behaves properly, but the motor doesn't turn it's time to replace the Jag.
Unread 28-01-2011, 21:01
Cody Trey's Avatar
ok, i'll get that checked
Unread 28-01-2011, 21:03
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
It was a problem with the U6 Gate Driver. Many teams had the problem if it was thermally shocked by heavy current from going from full reverse to full forward nearly instantly.
There was a design change, and that problem is now fixed.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 28-01-2011, 21:39
Check to make sure the two limit switch jumpers are installed before you replace the Jags.
Unread 28-01-2011, 22:25
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
How might one fix this, and use it as a practice jag?
Unread 28-01-2011, 22:32
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
You would have to replace the U6 Gate Driver. I believe the chip used is obsolete and difficult or impossible to come by. Not sure if there is a pin compatible replacement that could be found or not.
Unread 29-01-2011, 09:57
DonRotolo's Avatar
Back to humble
FRC #0832
Another troubleshooting technique is to remove all circuit breakers for the Jaguars except the one being tested. If that changes the problem check wiring.
Unread 29-01-2011, 10:07
In some cases the failure was so spectacular that the circuit board was burned through. You need to contact Luminary Micro to see if it can be fixed or simply replace with a newer version.
Unread 29-01-2011, 13:16
Cody Trey's Avatar
we have found out that it is not the jag. we have switched it out for other jags and same problem, we also checked the gear box, and re-greased it, the motor will go backwards and forwards when direct battery power is applied. We believe that is may be a problem in the code. we used c++ to program using the built in mecanumDrive->HolomicDrive(speed, direction, twist) function.
Unread 29-01-2011, 13:51
The Lucas's Avatar
CaMOElot, it is a silly place
It looks like you are using Polar not Cartesian style Mecanum. You need to supply a direction (calculate using 2 axis) , not an axis for the direction parameter. Are you doing that?
I would recommend for debuging using MecanumDrive_Cartesian() so you can just plug in an axis to each parameter. Just drive it forward and reverse to test the jags. Sorry if anything is misspelled, I am typing on my mobile without consulting docs
Robot Inspector
Unread 29-01-2011, 14:52
Cody Trey's Avatar
I am unfamiliar with MecanumDrive_Cartesian() could you please explain this more in depth. like what the parameters are?
Unread 29-01-2011, 15:11
If you have C++ installed, the WPI Library source code is on your hard disk.
void RobotDrive::MecanumDrive_Cartesian(float x, float y, float rotation, float gyroAngle)
X and Y are your joystick axes for Strafe(X) and Forward/Reverse(Y) respectively.
"rotation" is for turning (yaw rate) and can come from the twist axis of a 3-axis joystick.
