Go to Post Pushing match, what pushing match? If they can't catch you they can't push you around. - IndySam [more]
Unread 29-01-2010, 19:02
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
I've Got The Magnetic Encoders Working Over SPI
I just spent a day and half trying to figure out how to access the AS5030 magnetic encoders included in the kit over SPI. I finaly got it working and figured I could save others some time by posting my code here. As far as I can tell, there isn't an example for this out there anywhere. This isn't official, this is just the result of one person's research and tinkering, so don't trust it too far.
http://www.mediafire.com/file/nmtgyo...EncoderCode.vi
Please tell me what I did wrong and what could be improved.
Unread 30-01-2010, 18:02
Ryan Gordon Ryan Gordon is offline
FRC #2854 (EVHS Robotics)
Ryan Gordon is an unknown quantity at this point
Re: I've Got The Magnetic Encoders Working Over SPI
Nice, is there a particular reason how it worked out to be that "11111" is sent through the SPI?
Unread 30-01-2010, 23:16
AKA: Mark
Thats 11111 binary. The command you send to initiate a read is 00000, but because of the way the breakout board provides a 4 wire interface, commands sent to the encoder are inverted.
Unread 31-01-2010, 03:36
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
You're correct... there is no official example for using this sensor over SPI.
From looking at your code it looks like you are accessing it correctly. Well done! You could clean it up a bit by choosing Most Significant Bit First in the Advanced Config VI... then you wouldn't have to reverse the data you get back (don't forget to change the output command too). I would also make subVIs out of the Open and Get parts of the functionality to make it easier to include in user code and remain encapsulated.
-Joe
Unread 31-01-2010, 09:29
Gdeaver Gdeaver is offline
FRC #1640
For years with the IFI controller there were constant moans about the hardware SPI being tied up. Now that we have SPI there has been little talk about it. Good work. The AS5030 Is ok but there are better solutions out there. Avago makes a absolute magnetic encoder that is inexpensive and would be a good choice for some robo applications. Melix makes a good chip that comes on a demo board. It has some advantages over the Astria micro chip. Using spi can have advantages over the analog types.
Unread 31-01-2010, 13:32
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Nicely done! I really want to figure out someway to use the absolute encoders and accelerometer in the kit this year just to get the experience of using serial sensors now that we have them and they were free. Congratulations on the bus hacking!
Unread 28-01-2011, 22:15
StephenNutt StephenNutt is offline
FRC #0172 (Falgor)
StephenNutt is an unknown quantity at this point
Do you still have this code? I am interested in using the encoder this year and would like to use SPI.
Thanks
Steve
Unread 05-02-2011, 20:04
AKA: Mark
Here's that file again. Hope it helps!
http://mit.edu/mspatz/www/MagEncoderCode.vi
Unread 28-11-2011, 05:04
Ranjith Ranjith is offline
Ranjith is an unknown quantity at this point
Hi Techies,
Just I am checking the feasibility of using AS5030 with standard CPU SPI interface to our new design.
From my understanding the FET logic like Adapter board implementation is the way to interface AS5030 in Read/Write mode with standard SPI interface from CPU. I have documented my understanding. Please correct me if anything wrong...
And also can I get the code in viewable in text editor format (MagEncoderCode.vi), looks like it is Labview file and not able to open in text editor.
Thanks
Ranjith
File Type: pdf AS5030_SPI_Interface_Understanding.pdf (159.1 KB, 92 views)
Unread 28-01-2012, 16:07
brettreardon123's Avatar
brettreardon123 brettreardon123 is offline
FRC #1212
brettreardon123 is infamous around these partsbrettreardon123 is infamous around these partsbrettreardon123 is infamous around these partsbrettreardon123 is infamous around these partsbrettreardon123 is infamous around these partsbrettreardon123 is infamous around these parts
I'm going to try and resurrect this thread. I went and found these sensors, and we're going to try to use them this year for shaft encoding. When I open the VI you posted above, Labview cannot find most of the dependencies that are necessary. Does anyone know if this VI should still work in this year's copy of Labview, or is there an old dependency that was removed this year?
Thanks in advance!
Brett
Unread 28-01-2012, 16:17
Thanks in advance!
The location it is looking for the files is the 2009 location. You should be able to find them all in C:\Program Files\National Instruments\LabVIEW 2011\vi.lib\Rock Robotics\WPI
Unread 28-01-2012, 17:27
FRC #1212
Thank you! I was able to find all of the files except the first couple, "DigitalModule.ctl" "ConfigureAdvancedOptions.ctl" and "DIOChannel.ctl"
Do you know where I can find these?
Thanks again!
Brett
I've Been Working on the Robot Lyrics ipdude General Forum 1 25-01-2006 12:36
Aha! I've got the first page of the manual! IMDWalrus Rumor Mill 13 10-01-2004 00:51
forget the hampsters, i've got a better idea... archiver 2001 13 23-06-2002 23:43
