Our bot is running a four motor mechanum drive
all of our motors will go forward, but when we try to go back, one or two of them will not turn, any ideas? ![]() ask any questions you think may be relivant |
Re: Jaguar will not go backwards
Are these tan Jags by any chance? Failure in one direction only is a know failure mode of the Tan Jags.
they are tan, is there any way to fix this problem?
If it is a Jaguar hardware failure there is no competition legal way to repair it. Check and make sure that the lights on the Jaguars affected are changing the way you expect when powering in the direction that doesn't work. If the Jaguar light behaves properly, but the motor doesn't turn it's time to replace the Jag.
ok, i'll get that checked
It was a problem with the U6 Gate Driver. Many teams had the problem if it was thermally shocked by heavy current from going from full reverse to full forward nearly instantly.
There was a design change, and that problem is now fixed. |
#7
Check to make sure the two limit switch jumpers are installed before you replace the Jags.
#8
You would have to replace the U6 Gate Driver. I believe the chip used is obsolete and difficult or impossible to come by. Not sure if there is a pin compatible replacement that could be found or not.
#10
Another troubleshooting technique is to remove all circuit breakers for the Jaguars except the one being tested. If that changes the problem check wiring.
#11
In some cases the failure was so spectacular that the circuit board was burned through. You need to contact Luminary Micro to see if it can be fixed or simply replace with a newer version.
#12
we have found out that it is not the jag. we have switched it out for other jags and same problem, we also checked the gear box, and re-greased it, the motor will go backwards and forwards when direct battery power is applied. We believe that is may be a problem in the code. we used c++ to program using the built in mecanumDrive->HolomicDrive(speed, direction, twist) function.
#13
I would recommend for debuging using MecanumDrive_Cartesian() so you can just plug in an axis to each parameter. Just drive it forward and reverse to test the jags. Sorry if anything is misspelled, I am typing on my mobile without consulting docs |
#14
I am unfamiliar with MecanumDrive_Cartesian() could you please explain this more in depth. like what the parameters are?
#15
void RobotDrive::MecanumDrive_Cartesian(float x, float y, float rotation, float gyroAngle) X and Y are your joystick axes for Strafe(X) and Forward/Reverse(Y) respectively. "rotation" is for turning (yaw rate) and can come from the twist axis of a 3-axis joystick. Last edited by Ether : 29-01-2011 at 15:15. |
