Go to Post As long as they're not destroying each other, LET THE TEAMS PLAY! - Travis Hoffman [more]
Unread 28-01-2011, 22:57
Lawlhwut Lawlhwut is offline
None #2853
Lawlhwut is an unknown quantity at this point
Programming gyro, noob programmer
#include "WPILib.h"
class RobotDemo : public SimpleRobot
static const float Kp = 0.03;
RobotDrive myRobot;
Gyro gyro;
public:
RobotDemo(void):
myRobot(1, 2), // these must be initialized in the same order
gyro (1)
myRobot.SetExpiration(0.1);
void Autonomous(void) {
gyro.Reset();
while (IsAutonomous())
DriverStationLCD *screen = DriverStationLCD::GetInstance();
float angle = gyro.GetAngle(); // current heading (0 = target)
myRobot.Drive(-1.0, -angle / 30.0); // proportionally drive in a straight line
Wait(0.004);
screen->PrintfLine(DriverStationLCD::kUser_Line1,"KimpeeA ngle", gyro.GetAngle());
screen->UpdateLCD();
Wait(0.1);
myRobot.Drive(0.0, 0.0);
START_ROBOT_CLASS(RobotDemo);
This is the program i'm writing for the gyro. It is supposed to get the angle from the gyro and print it on the driverstation dashboard. But it is not compiling. Some fixes and basic syntax/structure info pl0x.
Unread 28-01-2011, 23:27
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
Re: Programming gyro, noob programmer
Generally when posting asking for help its a good idea to include any and ALL errors you get. You had a number of "{" and "}" that didn't match up. Most of your problems stemmed from the fact that you weren't closing some of your functions, and while loops and such.
Also, if you use [ CODE] and [ /CODE] without the spaces, when posting code, it stays indented making it easier to read.
#include "WPILib.h"
RobotDrive myRobot;
Gyro gyro;
public:
	RobotDemo(void): myRobot(1, 2), // these must be initialized in the same order
	gyro (1)
	gyro.Reset();
		Wait(0.004);
		Wait(0.1);
