Go to Post Haters gonna hate; kill 'em with kindness. - Taylor [more]
Unread 28-01-2011, 23:19
Re: cRio Kernel Error/Reboots
Originally Posted by Marc P. View Post
Is there anything else we can try?
At this point, I suggest you try a different cRIO.
Before that, though, check the 24v power and look carefully for metallic debris in the cRIO connectors and inside the chassis. You said you used compressed air, but that won't necessarily clean out sharp crumbs of aluminum.
