Go to Post You just have to care enough to give it a try. Your mentors will appreciate the effort. - Koko Ed [more]
Unread 27-01-2011, 15:11
nitneylion452's Avatar
AKA: Joe Lee
Re: Rookie Team Help- Robot Won't Move
He's probably referring to the circuit breaker (that black thing with the red button on top). Note that the red button isn't the power button. The power button is the little black arm that stick out from the side.
Unread 27-01-2011, 19:19
inou8it inou8it is offline
Captain/Founder/Student
inou8it has a spectacular aura aboutinou8it has a spectacular aura about
Yes the ON button is pressed. Here is an uploaded picture of our wiring, it still isnt working?
Unread 29-01-2011, 08:09
2bkrul's Avatar
2bkrul 2bkrul is offline
Whats tht burnin smell..oh the Jag!
AKA: Brandon Krul
FRC #0964 (Bedford Robotics)
2bkrul is an unknown quantity at this point
um...wheres the wireless gaming bridge (DLink)
"Building robots is a lot better with doughnuts around"
-Team 964 2010 Team Motto
Team 964 on TBA!
The Home of Bedford Robotics!
Unread 29-01-2011, 08:29
Do you have the driver station application running?
Tell us which of the main status lights and the Diagnostics status lights are green.
Swap the positions of the two unused cRIO modules to put them where they belong.
Are the status LEDs (one is yellow and the other green) on and blinking where your Ethernet cable is plugged into the cRIO port 1?
Are all the Digital Sidecar status lights on solid green? I can only see two in the photo, not the "batt" or 5v status lights.
Unread 29-01-2011, 09:18
DonRotolo's Avatar
Back to humble
FRC #0832
It will help us help you with answers to Mark's questions above.
A yellow flashing light on a Jaguar indicates it has power but no control signal. (More info here, pick the black jaguar getting started guide)
One possible cause for no control signal is missing or mis-wired PWM signals. The photos seem to show correct wiring, and you asserted that before.
Did you "enable" the robot from the driver's station? I'm not that familiar with it, but I remember there's a big red button on the display screen that needs to be green. A disabled robot cannot produce PWM signals.
Unread 29-01-2011, 10:01
harryji369's Avatar
harryji369 harryji369 is offline
Captian
AKA: Harry Indrataher
FRC #0369 (High Voltage)
harryji369 will become famous soon enough
you guys should really think about insulating your battery terminals
Unread 29-01-2011, 14:32
its all working thanks everyone!
Unread 30-01-2011, 11:09
Could you tell us what you did to get it going? Others searching for answers to similar problems might find it useful.
