Go to Post To me, as a student, it doesn't really matter how old the RoboCoach is. My only concern is that they don't get ape-crazy when the game starts. - AZNkommander [more]
Unread 29-01-2011, 08:35
Coach#3536 Coach#3536 is offline
2015 Carver 2nd Alliance Captain
AKA: The Hemi
FRC #3536 (Electro Eagles)
Coach#3536 is an unknown quantity at this point
Re: wireless communication sparatic/dangerous
Greg,
Im a Real rookie coach. When you say DS i have to go look that up. I will in a second, I am loading from a single laptop that has no other user access. All of the other applications are off. On the class mate no other software was available to the robot communication I believe.
You said,
On the cRIO, you don't mention a language, but each of the environments has a way to determine the CPU usage on the cRIO. If you are using LabVIEW, go to the Tools menu>>Real Time Module>>System Manager. For the best CPU readings, flip to the VIs tab, disable the Track checkbox, flip back to the Resources tab, disable disk and enable CPU, then press the button to Start Monitoring. This will not tell you what is hogging the CPU, but will tell you if it is occurring.
I am using lab view and have loaded code that was unchanced from the NI code. There are some errors when I run the code even with it being unchanged from NI. The thing that confuses me is when I wire direct to the robot the code errors don't impeed the robot fucntioning. When you say to go to LabView you mean to run it on the laptop the code is deployed from. Is this correct?
