Go to Post You mean how many Edible Data Analysis Metrics and Aggregated Measurable Entities (EDAMAME)? - Andrew Schreiber [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 29-01-2011, 11:08
Joseph Bisch Joseph Bisch is offline
FRC #2064 (Panther Project)
Joseph Bisch has a spectacular aura aboutJoseph Bisch has a spectacular aura about
Website Validation with regard to CSS3
My team's website uses CSS3 such as border-radius. It validates as CSS3; however, when one goes to the w3c css validator, the default option is to validate against the Level 2.1 profile. Of course the site fails to validate as 2.1.
I am planning on putting a page on my team's website about the website. I can mention that it validates as CSS3 there. How do you recommend making sure the judge for the website award validates the site as CSS3 and what do you think of this issue?
My team's website also uses the HTML5 DocType; however, by default the HTML validator uses the DocType to detect what it is validating so there is no issue.
Unread 29-01-2011, 18:18
perlgerl perlgerl is offline
Michelle
FRC #0781 (Kinetic Knights)
perlgerl is just really niceperlgerl is just really niceperlgerl is just really niceperlgerl is just really nice
Re: Website Validation with regard to CSS3
You can set the CSS validation options in the post of the called url.
For example, if your css file is at http://www.team123.com/stylesheets/stylesheet1.cscs,
the css validation link is,
http://jigsaw.w3.org/css-validator/validator?uri=http://www.team123.com/stylesheets/stylesheet1.css&profile=css3&usermedium=all&warning=1&lang=en
Unread 02-02-2011, 22:14
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
In my opinion, it's not that important to be 100% validated. I used to be super anal about this, but have learned that it really doesn't matter as long as the site works and is consistent across all major browsers.
Obviously you want good HTML and CSS, so don't do anything dumb, but also realize that you don't need 100% validation in order for your site to work. An example of this would be not worrying about Youtube embed code not being validated.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 03-02-2011, 16:27
Thank you perlgerl, that was the kind of solution I was looking for.
GGCO, I agree that there are times that one should not bend over backwards to make a site pass validation, such as when doing so would involve making a change that hurts browser compatibility. However, there are points for the website award if a team's site is valid HTML and CSS.
Unread 03-02-2011, 21:31
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
I thought that the CSS3 spec wasn't finalized yet, which is why the validator doesn't default to check against it...?
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
Unread 05-02-2011, 19:10
dqmot17's Avatar
dqmot17 dqmot17 is offline
Orange Hat
FRC #0247 (Da Bears)
Team Role: Webmaster
dqmot17 can only hope to improve
Send a message via AIM to dqmot17
I end up referring to the FIRST website as a standard (albeit it is not the best), and they 57 CSS errors, so clearly the browser compatibility is the key here (IE is a horror to code for)
2009 Championship Finalists & 3 Blue Banners
