Go to Post Actually, I forsee two [buttons]: Fire and "Thats the opponents target, you dumb robot" - devicenull [more]
Unread 29-01-2011, 11:23
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
Tetrix Motor Fix
After our motor only stalled for about 2 seconds yesterday, we found that it wasn't working. We took apart the motor, and found that the resistor was burnt. We couldn't find anything else on CD about the resistor value and were wondering if anyone else knew what resistor to replace it with. We know it wouldn't be legal for competition, but just for testing purposes, we thought it would be fine.
Thanks for the help!
Unread 29-01-2011, 11:35
REVving up for a new season
FRC #2848 (All-sparks)
Re: Tetrix Motor Fix
http://www.chiefdelphi.com/forums/sh...ad.php?t=89848
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 29-01-2011, 11:37
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Please read the whole thread here. You'll get the details you need, including the legal and logical fix.
<Greg beat me to it, same thread.>
-Michael Dessingue
Unread 29-01-2011, 11:46
avanboekel's Avatar
I've searched that thread, and am not finding the type of resistor that I would need.
Unread 29-01-2011, 12:18
The reason you are not finding a resistor value to replace the part with, is because it is not a resistor. Even if it was one, it would not be a logical fix. Because the motor has precisely placed magnets inside, when opened, their alignment is thrown off and thus the motor performance is degraded. My suggestion is to replace the whole motor with a new one and use the thermal protection cable for the power adapter, linked to in the previous thread.
-Michael Dessingue
Unread 29-01-2011, 12:24
Malikov16's Avatar
Malikov16 Malikov16 is offline
FRC #2338 (Gear It Forward)
Team Role: Electrical
Malikov16 is an unknown quantity at this point
In the post it says to replace the resistor. We already ordered new motors which we are saving for competition, but we need motors to work right now so we can work with our minibot.
Unread 30-01-2011, 13:44
If you want motors to use to design around and will operate as new motors will in competition, wait for the new motors to arrive in the mail. As mentioned before, the piece you fried, and refer to as a resistor, is in fact not a resistor. Also even if it was, and you replaced that alone, the motor will not operate as it did before you opened it, so any design you make using the failed motor will not act the same when a new motor would be set in it. Wait the few days now for the new motor(s) to arrive, and it will save you the whole regional experience of rebuilding your minibot there.
-Michael Dessingue
Unread 30-01-2011, 14:04
Chris is me's Avatar
AKA: Pinecone
There is no legal fix for their existing motors - only for preventing new motors from burning out.
Unread 04-02-2011, 01:01
WarehouseCrew WarehouseCrew is offline
FRC #3299 (Warehouse Crew)
Team Role: Parent
WarehouseCrew is an unknown quantity at this point
Could anyone using the Tetrix fuse protected motor power cable answer a couple questions:
1. Does it prevent burning up the Tetrix motors (eg. live up to its promise)?
2. Does the fuse act like a circuit breaker (eg. when it cools down it works again) or do you need to replace the fuse/power cable once it has prevented a motor stall ($9 vs. $30 for motor)?
3. If it is a "fuse" that is destroyed while preventing damage to the motor; can just the fuse (hopefully less that $9) be replaced on this cable without violating the FIRST rules?
Thanks.
Unread 04-02-2011, 09:35
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
The fuses being mentioned in various places are part of the battery pack. They are mini blade types and reside inside that black bump on one of the wires coming out of the battery pack. If your motor(s) are not running, check the fuses first. Either remove it and check for continuity or just check the wires out of the battery pack for voltage.
A team update has allowed us to use lower amperage fuses. We're currently running one motor on a 4A fuse. I recommend getting a few lower amperage fuses at the very least. I cannot tell you anything about the thermal protector that is available. I also await reports from those who are using them.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 04-02-2011, 10:04
Warehouse,
The $9 Thermal protector is an auto resetting device. The smaller fuse in the battery is not a resettable device and will need to be replaced when/if it burns open. I am sure your mileage will vary on either device. The failures are caused by various designs and the stall characteristics each provides to the motors.
