Go to Post Also, there are times when the folks who run this ice cream store don't have the flavors I like. Can you believe that?!!! Although this really frustrates me, I get over this treachery and I still order something. After all, it is ice cream. I like ice cream. - Andy Baker [more]
Unread 27-01-2011, 10:13
wdell wdell is offline
AKA: William Dell
FRC #3999 (Shadetree Mechanics)
wdell has a spectacular aura aboutwdell has a spectacular aura about
Re: Driverstation / Dashboard in JAVA
I completely eradicated Netbeans from my computer and reinstalled... twice. Found the problem. Whatever is going on, even though my machine was claiming it had 2011.4 installed it hadn't actually updated the libraries. Got it sussed now, and yes, that line is broken.
Haven't had a chance to test the 0 byte workaround, won't be near my lab for a couple hours yet.
Unread 27-01-2011, 12:13
frasnow's Avatar
frasnow frasnow is offline
Software
frasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to behold
Originally Posted by Joe Ross View Post
It's in the wpilib tracker http://firstforge.wpi.edu/sf/go/artf1322
Thanks Joe!
Unread 27-01-2011, 13:52
AKA: William Dell
The zero byte workaround is good. You don't get a reading for the Solenoids on the dashboard, but you don't get error messages either.
Unread 27-01-2011, 18:00
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
With version 2011.4 I observed that the posted dashboard code does not properly map the digital i/o pins on the sidecar to the leds on the dashboard gpio state and gpio output enable. First two leds are always off and led 3 maps to digital i/o 14. i/o 1 and 2 do not change any led on the dashboard.
The following code works properly:
                        int dioData = 0;
                        for( int i = 1; i <= 14; i++)
                            if( DigitalModule.getInstance( module ).getDIO( i ) )
                                dioData |= ( 1 << i-1 );
                        lowDashData.addShort((short)dioData);
                        int dioDir = 0;
                            if( DigitalModule.getInstance( module ).getDIODirection( i ) )
                                dioDir |= ( 1 << i-1 );
                        lowDashData.addShort((short)dioDir);
There seems to be a problem with getAllDIO() and getDIODirection().
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 28-01-2011, 19:00
TPNigl TPNigl is offline
FRC #0069 (Team HYPER)
TPNigl is an unknown quantity at this point
We are getting the problem that it is looking for v_20 and we already updated to v_25. We tried the above code and everything worked except the version error. Any ideas?
2011 Pit Crew:
2011 CT Xerox Creativity Award
HYPER Alumni
Unread 28-01-2011, 19:08
It sounds like you didn't install the 2011 version of the java plugins.
Unread 29-01-2011, 12:07
DCRich DCRich is offline
FRC #2180 (Zero Gravity)
DCRich is an unknown quantity at this point
We rev'd back to 2011.3 and the dashboard is now working!
Ughh how much time we have wasted :-(
Unread 29-01-2011, 14:01
frasnow's Avatar
Software
Yeah, I'm really upset about the lack of proper testing on 2011.4. We're supposed to be teaching the students good programming practices. Releasing something that breaks example code and not fixing it quickly is pretty bad.
Does anyone know if using the latest is required at events?
