Go to Post Not only would it be cool but the mental image of Dave's suffering when he writes a message in unintelligible characters makes me grin uncontrollably. - Andrew Schreiber [more]
Unread 29-01-2011, 12:43
Carter12s's Avatar
Carter12s Carter12s is offline
Team Cap
FRC #3374 (Robo-Broncs)
Carter12s is just really niceCarter12s is just really niceCarter12s is just really niceCarter12s is just really nice
3374 Robot Custom Line Tracking and early teaser...
This is a cute little early season summary:
http://www.youtube.com/watch?v=-dAEv7o-Nhs
, and this is a pretty sweet little line tracking test:
http://www.youtube.com/watch?v=QGbMw..._order&list=UL
Programing is the real way to build a robot.
Unread 29-01-2011, 18:04
wazcodez's Avatar
wazcodez wazcodez is offline
AKA: Megh Suthar
FRC #2076 (Blackscots)
wazcodez is infamous around these partswazcodez is infamous around these parts
Send a message via MSN to wazcodez
Re: 3374 Robot Custom Line Tracking and early teaser...
Hey ! Can I get the code for your custom line tracker since i have no idea how to program it ..
thanks
" When you copy from one source it's called plagiarism when u copy from multiple it's Research .. ! " - Megh Suthar
Unread 29-01-2011, 18:14
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
That line tracking is extremely interesting! I really enjoy how you use the strafing ability of the mecanum to adjust where it is on the line rather than rotating the bot and changing the orientation in respect to the field.
Everything is looking great! Keep up the hard work!
Unread 29-01-2011, 23:24
Carter12s's Avatar
Team Cap
Smile Re: 3374 Robot Custom Line Tracking and early teaser...
I don't have a copy of the code with me right now, but i will post one tomorrow. The general idea is that I took the three boolean inputs from the line sensors and built them into an array. I then convert the array into an integer which feeds into a case structure. The case structure picks what the appropriate horizontal movement should be for the each combination of the sensors. When i can take some screen shots of it I will put them up. Thanks for the interest!
Carter Schultz
Unread 29-01-2011, 23:41
wazcodez's Avatar
AKA: Megh Suthar
Carter Schultz
Thanks Carter
Unread 30-01-2011, 00:40
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
I assume that cim motor on the lift is just for testing, there are only 4 allowed on the robot this year.
2016 Central Illinois Winner. Curie Division finalist
Unread 30-01-2011, 09:16
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
I would love to see the code as well if you don't mind sharing. This was exactly what i was thinking of doing(using strafe to follow the line) but are mechanum wheels have not arrived yet so are programmers are kinda dead in the water.
Unread 30-01-2011, 18:00
Carter12s's Avatar
Team Cap
Here is the code i have so far. The only thing that it is missing is instructions for when to stop moving forward and exit autonomous. The important thing to remember when working with this code is that a joystick produces a negative number when pushed forward. So the numbers are reversed from what seems intuitive. The timers at the top are really just to provide a reference for how fast this code can be run.
