Go to Post Even if this is the Rumor Mill, there are behaviors that need to be adhered to. - meaubry [more]
Unread 29-01-2011, 13:14
isaac77 isaac77 is offline
FRC #3583
isaac77 is an unknown quantity at this point
Help with minibot, pleaase!
Hello, this is team number 3583 and we are a rookie team. I am wondering if someone can help us by sending us pictures and ideas of the minibot.
Unread 29-01-2011, 13:22
soxfan269's Avatar
soxfan269 soxfan269 is offline
FIRST Team 3620 Team Member
AKA: Daniel Michaels
FRC #3620 (Average Joes)
soxfan269 is an unknown quantity at this point
Smile Re: Help with minibot, pleaase!
We have decided to use magnets, we have brainstormed, tested, and prototyped many ideas, and that is my main suggestion to you. Also remember the wheels have quite a bit of grip to them. I am a fellow rookie teamer myself, and we right off the bat decided to build the pole that the minibot would climb. Without doing this all prototyping is quite useless. The specs for the pole are on the kit of parts website
Unread 29-01-2011, 13:25
FRC #3583
Yeah, thats a good Idea thanks(; Have you all finished your minibot?
Unread 29-01-2011, 13:32
soxfan269's Avatar
Red face Re: Help with minibot, pleaase!
I would not further that design avanboekel on the basis that the minibot has to run on the battery power and the motors alone, no outside force is permitted. once its on the pole it is up the the electrically powered motor to move the minibot up the pole
Unread 29-01-2011, 13:34
FRC #3583
WOW, that's a great design thanks
soxfan269's Avatar
We have yet to finish our minibot, as a 30 some member team we are able to have sub groups for each task. Our minibot team is currently on its third design which they think is their best so far. They have yet to test it but it seems promising. It takes advantage of magnets to hold it onto the pole
Unread 29-01-2011, 13:39
FRC #3583
@soxfan269 thanks for the help. Where you all from?
Unread 29-01-2011, 13:43
soxfan269's Avatar
Thumbs up Re: Help with minibot, pleaase!
Your welcome and we're from Southwest michigan in a town called St. Joseph. I hope I've been of some help if you need any more feel free to send me an email at soxfan269@hotmail.com
Unread 29-01-2011, 15:53
FRC #3583
hey bro are we allowed to use push sensors from lego mindstorm?
Unread 29-01-2011, 17:18
Bob Steele's Avatar
AKA: Bob Steele
The button (limit switch) sensors from mindstorm are legal... they are wired to be used with the NXT computer iinterface... you might be able to use them another way but it will be tricky and you will need to find some way to wire them..
R
Unread 29-01-2011, 17:57
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
My advice since your a rookie team, and I don't mean to discourage you, but I would leave the minibot alone. It's your first year and I feel like doing this could set you up to fail, you should just go and make sure all the essential systems work, before you make a whole second robot.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 05-02-2011, 13:20
FRC #3583
So then can we use the touch sensor?
