Go to Post Remember, however, that such software limitations in no way approximate the functionality of a multiple-speed, mechanical transmission. They're simply a convenient way of limiting your students' lead feet. - Madison [more]
Unread 29-01-2011, 14:21
earlybird's Avatar
earlybird earlybird is offline
They tried to ship me 2 competition
AKA: Robbie Oehrli
FRC #2849 (Team Ursa Major)
earlybird is a jewel in the roughearlybird is a jewel in the roughearlybird is a jewel in the rough
Re: how to set up the pnematic system
You will probably want to buy some push to connect fittings at some point, you can get the from McMaster-Carr (http://www.mcmaster.com/#push-to-con...ctors/=asy4yj). They are brass fittings that allow you to connect the pneumatic tubing to things such as, the compressor, regulators, tanks, pistons, and all your other brass fittings etc. And don't forget to use pipe thread tape on all your fittings, my team didn't use it our rookie year and our entire system leaked.
Hope this helped.
Unread 29-01-2011, 16:55
Bill McKinney Bill McKinney is offline
Bill McKinney is an unknown quantity at this point
Hope this helped.
We are also a rookie team using pnuematics. So with the fittings you recommend from McMaster, do you just stick the tubing into the end of the fitting? If the tubing is 0.25", what should the OD be on the threaded end assuming it is a male end?
Bill McKinney, Team 3711
Unread 29-01-2011, 17:18
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
The OD on the thread is determined by the port on the actuator that you choose. For example most of the free actuators Bimba offers (3/4"-2" bore) use 1/8 NPT fittings.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
