Go to Post It's always FIRST season. - Foss@Team176 [more]
Unread 29-01-2011, 14:05
pintsize131 pintsize131 is offline
FRC #1111
pintsize131 is an unknown quantity at this point
Threaded shafts
Are there any websites other than AndyMark and McMaster-Carr that sell threaded shaft extensions? I'm not sure AndyMark even sells them, and McMaster-Carr doesn't sell the size we need. Any ideas?
Unread 29-01-2011, 14:50
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Re: Threaded shafts
I see you are in Maryland have you tried Grainger or TEA Machine?
www.grainger.com
http://www.teausa.net/index.aspx?mid=5
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 29-01-2011, 15:03
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Threaded shafts
Try Small Drive Proucts. Also look at MSC.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 29-01-2011, 15:19
FRC #1111
Re: Threaded shafts
I just tried both, but grainger seems so overwhelming when I'm working on my own. I'll try again tomorrow when my mentor is actually here to help. The second one doesn't seem to actually sell anyhing, and even if they did, they do not seem to have the type we need. Thanks for the suggestions though
We're looking for a way to extend the output shafts on the CIMple boxes, which would require a 1/4-20 threaded end, and a 1/2" diameter for the shaft.
Unread 29-01-2011, 15:27
rsegrest's Avatar
Re: Threaded shafts
Dang, if I had known that's what you were looking for!
We needed a 7 in shaft for the CIMple box (I assume you are talking about the shaft that goes through the wheel). Since Andy Mark doesn't make one we ordered the Long T-Box Shaft and then had the head machined to match the shorter shaft that came in the KoP. Does that help?
~ Unknown
Unread 29-01-2011, 15:29
FRC #1111
Re: Threaded shafts
It very well might! Thank you so much! I'll check with my mentor and see if that is possible.
