Go to Post Dave Lavery was right... all we had to do was type in "attack old lady" and when we started up our robot it did. - Human Player [more]
Unread 29-01-2011, 16:29
FirebearBenD's Avatar
FirebearBenD FirebearBenD is offline
FRC #2846
FirebearBenD is an unknown quantity at this point
Minibot Design Insufficiency (Contact Pressure Based)
My team has a fairly basic minibot design - a couple plates of metal, a couple traditional wheels designed to move up the pole, and a motor. We're thinking we don't have a terrible design idea, as we can get the minibot to move up the pole at a decent rate if we press the minibot against the pole. However, without a human hand, we aren't seeming to get enough contact pressure between the wheels and the pole for the minibot to climb effectively. Naturally, adding weight (our first idea) would slow the minibot down too much and make it above the 15 lb weight limit, so we were wondering if there were other methods that could get us the necessary contact pressure.
Unread 29-01-2011, 16:37
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: Minibot Design Insufficiency (Contact Pressure Based)
Did you try using a "lever-arm" to get more force on the wheels?
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 29-01-2011, 17:15
Bob Steele's Avatar
AKA: Bob Steele
Put your two wheels on two pieces that are hinged together and use surgical tubing to make them "compress' onto the pole.
the only trick will be how to place the surgical tubing in such a way that you can get the minibot on the pole at deployment and still provide an inward force wheel to pole.
Good luck
Unread 29-01-2011, 18:25
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Have you thought about magnets at all?
