Go to Post Each match is a learning experiance - the only thing you can do is get better. - SuperJake [more]
Unread 29-01-2011, 17:06
frenchie4111 frenchie4111 is offline
None #1111
frenchie4111 is an unknown quantity at this point
Strafing Mecanum with Gyro
Our team has installed a Gyro, the gyro is zeroed, and in the exact middle of our bot. We can read the values, and we put the gyro angle directly into the Holonomic Drive gyro input. We have noticed that this helps our robot move forward in a very precise line, but does not help our strafing ability, and it is easier/more precise to self correct instead.
We would like to know if there is a way to make the Gyro improve our strafing capabilities.
[url="http://mylifeisnerdy.co.cc"]My Life Is NerdyURL]
Unread 29-01-2011, 17:13
Chris is me's Avatar
AKA: Pinecone
Re: Strafing Mecanum with Gyro
What about your strafing capabilities do you find difficult right now? What problems are you trying to solve?
Unread 29-01-2011, 18:08
None #1111
It does not strafe perfectly, it rotates while it is going
Unread 29-01-2011, 22:27
jackinabox jackinabox is offline
FRC #2497
jackinabox is an unknown quantity at this point
Are you using PWM? Last year we had a meccanum drive on PWM and had the same problem. This year we are using CAN, and our meccanum setup drives PERFECTLY.
Unread 30-01-2011, 06:35
It sounds like you need to post code or math describing your control method. Also, are you using a polar form of robot drive?
Greg McKaskle
Unread 30-01-2011, 12:52
None #1111
Do you know what your code was like that made it work perfectly with CAN?
And I will post my current code once I get a screen shot.
Unread 01-02-2011, 21:35
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
I must admit that I didn't give this notion much credit but I suppose using a digital setting with CAN vs a timed signal from PWM may actually merit looking at more closely. Do you have an explanation as to why there might be a difference or is it just an observation? Anyone else have input?
Steve
