Go to Post I don't resent or envy them for being strong teams; I hope we can continue to learn from them and someday join their ranks. - dsmoker [more]
  #46   Spotlight this post!
Unread 29-01-2011, 13:50
Eulipian's Avatar
Eulipian Eulipian is offline
FRC #2090
Eulipian is an unknown quantity at this point
Re: Team Update #6
[quote=340x4xLife;1010986]
That's a BIG difference this late in the season. If they didn't want defense played between the towers then penalize it from the get go.
http://www.chiefdelphi.com/media/photos/36093
It is a radical change that should have been included in the original rules. I think the observation that blocking bots from leaving rather than entering is a good adaptation to this change. Also, pinning is more important and has to be part of defense, stalking the other Alliance's line to prohibit entry won't work, weight, wheels and drive train of bots built to block all have to be chosen for strength and stability vs. maneuverability. Quick light maneuverable blocking bots are going to be penalty factories for the opposition unless they keep to the middle.
  #47   Spotlight this post!
Unread 29-01-2011, 15:05
Bob Steele's Avatar
AKA: Bob Steele
Re: Team Update #6
So here is an idea on the retrieval of the minibot...
At the end of the match... a little door opens on your minibot and a rope falls down...allowing you to pull it down...
Someone tell me what they think of the legality of this... It would deploy after the match was over...
Tell me what you think
Bob
  #48   Spotlight this post!
Unread 29-01-2011, 17:17
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Team Update #6
Originally Posted by 340x4xLife View Post
Would you even consider this robot if the current ruling was in place in week 1? http://www.chiefdelphi.com/media/photos/36093
In a word, YES. I still believe that team is going to be one of the most unique robots strategically and a valuable asset to an alliance. They can play defense anywhere they want, not just at the line. I would hope that they can make the sides go up and down at a reasonable pace though(up to get in place, down to stay in place). Besides that, there is still ambiguity as to what happens when you push a robot into it. I think that if you don't make a slight attempt to go around them, then you(scoring bot) is at fault regardless of them being near the line. If you try to go around and they move into your way, then it is their(defense bot) fault. I hope they clarify it this way in the updates though. It should make it more cut and dry for refs and make the punishment fit the crime more.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
  #49   Spotlight this post!
Unread 29-01-2011, 17:29
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: Team Update #6
I completely agree (as I stated earlier) that defense just needs to be played in the middle of the field, and played to delay them getting to the scoring zone. I don't think it will be hard with good defense to double or triple the amount of time it takes a robot to traverse the field and score.
I am still concerned with the idea that if you get pushed into an opponent's robot in the lane or in the scoring zone you get a red card. For example, you get a tube and come out of the lane toward the middle of the field (side note: I think that against a defender coming out of the lane along the edge of the field will make it very tough to get to your scoring zone) and the defending robot blocks and shoves you back, pushing you back into their scoring zone and one of their allies.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
  #50   Spotlight this post!
Unread 29-01-2011, 23:55
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Team Update #6
Bob
Genius!
<R92-J> Allows rope, and there aren't any limitations on its length.
2017 Scoring Model
CAD Library | GitHub
  #51   Spotlight this post!
Unread 29-01-2011, 23:59
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: Team Update #6
Originally Posted by JesseK View Post
Genius!
Yes there is. Your minibot cannot excede the 12x12x12 at anytime.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #52   Spotlight this post!
Unread 30-01-2011, 00:33
Re: Team Update #6
During the match. If I have a 12" cube, and I take the top cover off by a hinge (disregarding legality of that for a moment--bear with me), and that top cover is 6" thick, I now have a 12" by 24" by 6" block. I'm in the pits, or accessing the NXT before the match (or after the match) to turn it on or off. Am I illegal?
Spoiler for answer:
No. I do have to make certain that that cover can't come loose during a match, though.
If, at match end + 30 seconds or so, a minibot dropped a rope to about the 6' mark, making it easy to grab, I think it would be legal, because it's after the match. However, that rope/cord/string would have to be inside the cube the entire match.
I like the idea, but I'd probably suggest asking Q&A about this.
  #53   Spotlight this post!
Unread 30-01-2011, 01:23
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: Team Update #6
does anyone know if it is legal to stand on the base of the tower to retrieve the tube? if it is then all you really need is a pretty tall guy on the drive team every match.
  #54   Spotlight this post!
Unread 30-01-2011, 01:42
nitneylion452's Avatar
AKA: Joe Lee
Re: Team Update #6
The update says you must be standing on the floor.
  #55   Spotlight this post!
Unread 30-01-2011, 13:38
SirTasty's Avatar
SirTasty SirTasty is offline
Middle Manager... :-(
AKA: Dolan Murvihill
FRC #2374 (CrusaderBots)
SirTasty is a splendid one to beholdSirTasty is a splendid one to beholdSirTasty is a splendid one to beholdSirTasty is a splendid one to beholdSirTasty is a splendid one to beholdSirTasty is a splendid one to behold
Re: Team Update #6
Spoiler for answer:
Looks within the rules to me, just remember that after the match isn't when time runs out; it's ten seconds until after time runs out OR until everything comes to rest, which means that if you drop a rope five seconds after the buzzer while minibots are still climbing, you're in trouble.
Originally Posted by davidthefat View Post
Another note: sportsmanship and competition go hand and hand. In any sport, whether it is football or track and field. As the ball is snapped, you pound the guy across you and drive him until he is on his butt. After the whistle blows, you help him on his feet; repeat every down.
Homework? What's homework?
  #56   Spotlight this post!
Unread 30-01-2011, 14:05
Chris is me's Avatar
AKA: Pinecone
Re: Team Update #6
Have fun wiring a minibot to drop a rope after the match without an NXT.
If you do have an NXT - you don't exactly need the rope...
  #57   Spotlight this post!
Unread 30-01-2011, 14:18
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Re: Team Update #6
The minibot coming back down shouldn't really be that much a problem. Everyone's trying to shave off as much weight as possible, which means the massive weight (proportionally) of the battery should ( i didnt say will) be enough to make the wheels slide nicely back down.
P.S. has anyone actually found out yet if the battery is enough to pull it back down?
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
  #58   Spotlight this post!
Unread 30-01-2011, 14:29
pfreivald's Avatar
AKA: Patrick Freivald
Re: Team Update #6
MINIMARIA doesn't backdrive off the pole in her current incarnation, but she falls right off with a good shake...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #59   Spotlight this post!
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
Re: Team Update #6
On at least one of our minibot designs the battery weight is not enough to drag it back down.
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
  #60   Spotlight this post!
Unread 30-01-2011, 15:09
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Team Update #6
On the only one of our 3 minibot designs to be tested, the bot does fall back down under its own weight if the motors are not running. This is using a magnetic gripper to the pole.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
