Go to Post I have postulated a theory that it is due to a resonance between gravity waves and the color purple. - petek [more]
Unread 29-01-2011, 17:22
Left Justified Left Justified is offline
AKA: Calvin Norman
FRC #2647
Left Justified is an unknown quantity at this point
Problems controlling spike
In LabVIEW we have created a victor and are setting the output value to one, but when we measure the output voltage on the spike it is zero volts.
However, within the driver station we have seen a response to the correct PWM.
What value should we be setting the output on the victor in order to make the spike run correctly?
Thanks in advance.
Unread 29-01-2011, 17:26
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Problems controlling spike
You need to first not call for a victor in your code, but look for the Relay VI set. Open a relay in your begin.vi and close it in the appropriate one, then use the relay code in teleop.vi.
Also, you need to plug your spike into a relay slot on your digital sidecar.
I'm right 90% of the time, so why worry about the other 3%?
Unread 29-01-2011, 17:43
AKA: Calvin Norman
FRC #2647
Thank you.
Where can you find the Relay VI set?
Unread 29-01-2011, 17:51
Cecil's Avatar
AKA: Alex Hummel
I dont have it up in front of me, but i believe it is under the actuators category. Its in the same category as Solenoids.
