Go to Post Replay/video isnt a BAD idea, its just not a GOOD idea for FIRST. - Ashley Christine [more]
Unread 29-01-2011, 16:19
americandevilz americandevilz is offline
FRC #1923
americandevilz is an unknown quantity at this point
Ps3/360 controller with robot programmed in Java
Hi all,
We're interested in knowing how our team could drive our robot using a Ps3 controller/Xbox 360 controller. We are programming our robot in Java. Can anyone help us out? Thanks.
Unread 29-01-2011, 17:32
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
Re: Ps3/360 controller with robot programmed in Java
The driver station should see it as a Joystick. Install any drivers you would normally need (google for them), and then the controller should have its hats (the sticks) enumerated as axes and buttons numbered.
Unread 29-01-2011, 20:55
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
If you're having problems figuring out which axis/buttons on the controllers are which, go to Control Panel > Game Controllers.
Then, you select the game controller and click properties. Now, you can calibrate your device and see which axes is which number, and which button is which.
Hint: Look at the documentation for the Joystick class for more information on how to read Joystick inputs.
Unread 30-01-2011, 15:00
architek501 architek501 is offline
FRC #0501
architek501 is an unknown quantity at this point
My edits are getting a bit excessive, sorry. I'm in a situation similar to OP's, and I wanted to get the D-Pad working properly.
I thought I had found the solution to my problem. I just need to find out what the "Point of View Hat" (The D-Pad) is according to the WPI Libraries.
I know that Left-Right movement is read as Axis 6, but Up-Down movement is either not recognized by the Joystick class (being an axis higher than 6), or something else that I'm not thinking of.
Last edited by architek501 : 30-01-2011 at 15:20. Reason: Re-stated problem. Getting frustrated.
Unread 30-01-2011, 18:13
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
it only has six axes
Unread 30-01-2011, 18:23
FRC #0501
One would think... but I actually found 7.
Left Analog Up/Down (Axis 2)
Left Analog Left/Right (Axis 1)
Right Analog Up/Down (Axis 5)
Right Analog Left/Right (Axis 4)
D-Pad Up/Down (Axis 7?)
D-Pad Left/Right (Axis 6)
Left/Right Triggers (yes, for some reason, these form their own set of axes, where pressing the left trigger outputs a positive value, and pressing the right trigger outputs a negative value) (Axis 3)
Unread 31-01-2011, 10:55
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
If you would like to use a PS/3 controller you need a program called motionjoy to use its full funtionality. Our team is using a PS/3 controller with its 7 axis capibilities its very stable and easy to use.
Programmer Matt
Gus Robotics, team228.org
Unread 31-01-2011, 10:57
FRC #0228 (Gus)
Sorry but the D-Pad is not an axis the 7 axis's are
Left Right joysticks would be 4
tilt foward back side side would be 2
and the variable triggers is 1
Programmer Matt,
Unread 31-01-2011, 18:22
FRC #0501
Originally Posted by ProgrammerMatt View Post
S
If I were using a PS3 controller, that would definitely be the case.
    public static int getDPad1( )
        return 6;
This is a snippet of code I'm using in a config file that is imported into our main robot code, referenced here:
if ( opControl.getRawAxis( ControllerConfig.getDPad1( ) ) >= 0.03 )
                System.out.println( "This is Axis #6." );
In this case, when the robot is running in teleoperated mode, and the D-Pad is pressed to the right, it prints "This is Axis #6." This is placeholder code, but it's apparent that if I try to create and call a 7th axis, it won't work. I just want to know if there's some sort of workaround so I can use the Up-Down axis of the D-Pad.
