Go to Post If you're not trying to make the best possible product given your set of constraints and resources I'm not quite sure what you're doing. - Aren_Hill [more]
Unread 29-01-2011, 17:33
wmarshall wmarshall is offline
FRC #0011
wmarshall will become famous soon enough
Re: Jaguars do not work except in percent vbus mode
This bit my team, too. In anything but PercentVBus, a few extra calls have to be made. You're using voltage, so the Jaguars can do the referencing internally, so no external references have to be set.
However, for any control mode that needs to go to a setpoint, you need to set and tune the Jaguars' internal PID loop. In addition, you have to manually enable control. Use something like
jag.setPID(1,1,0);
jag.enableControl();
without the made-up numbers. I'd recommend the BDC-COMM utility to tune the loop, as it drastically simplifies things.
