Go to Post I tried, but our freshmen lost enthusiasm about filing the blocks of aluminum I gave them into Andymark Performance Wheels after only a few hours! - Greg Woelki [more]
Unread 29-01-2011, 12:07
Cody Burd's Avatar
Cody Burd Cody Burd is offline
FRC #3607 (Technologic)
Cody Burd is a name known to allCody Burd is a name known to allCody Burd is a name known to allCody Burd is a name known to allCody Burd is a name known to allCody Burd is a name known to all
how to set up the pnematic system
hi we are team 3607 asnd we have no idea of how to set up the pnematic system can anyone help
Unread 29-01-2011, 13:24
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: how to set up the pnematic system
Do you have any specific questions? You should start by reading Section 4 of the manual, 4.3.11 and the 2010 pneumatics manual located here; http://www.usfirst.org/uploadedFiles...%20Rev%20-.pdf
If you still have questions, feel free to ask, theres a lot of knowledgeable people on here.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 29-01-2011, 14:20
Eigenvector's Avatar
Eigenvector Eigenvector is offline
AKA: Xander
FRC #1002 (CircuitRunners)
Eigenvector is an unknown quantity at this point
Anything specific you need help with? If you need anything, shoot me a message and I'll get back to you as soon as I can.
Unread 29-01-2011, 14:21
earlybird's Avatar
earlybird earlybird is offline
They tried to ship me 2 competition
AKA: Robbie Oehrli
FRC #2849 (Team Ursa Major)
earlybird is a jewel in the roughearlybird is a jewel in the roughearlybird is a jewel in the rough
You will probably want to buy some push to connect fittings at some point, you can get the from McMaster-Carr (http://www.mcmaster.com/#push-to-con...ctors/=asy4yj). They are brass fittings that allow you to connect the pneumatic tubing to things such as, the compressor, regulators, tanks, pistons, and all your other brass fittings etc. And don't forget to use pipe thread tape on all your fittings, my team didn't use it our rookie year and our entire system leaked.
Hope this helped.
Unread 29-01-2011, 16:55
Bill McKinney Bill McKinney is offline
Bill McKinney is an unknown quantity at this point
Hope this helped.
We are also a rookie team using pnuematics. So with the fittings you recommend from McMaster, do you just stick the tubing into the end of the fitting? If the tubing is 0.25", what should the OD be on the threaded end assuming it is a male end?
Bill McKinney, Team 3711
Unread 29-01-2011, 17:18
AKA: Scott
The OD on the thread is determined by the port on the actuator that you choose. For example most of the free actuators Bimba offers (3/4"-2" bore) use 1/8 NPT fittings.
Unread 29-01-2011, 18:21
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
The standard pneumatic system contains two main parts, a high pressure side and low pressure side. The high pressure side of a pneumatic system contains:
-a compressor (you can do without it, but we'll get to that later)
-automatic relief valve
-pressure switch
-pressure gauge
-accumulators
-vent valve
The compressor is what builds pressure in the system by forcing air into the accumulators (air storage tanks), without letting air escape. The automatic relief valve is used to automatically release pressure once it builds to a certain point (for FIRST competition it must be calibrated to 125psi, which can be done simply with a wrench). You must include a pressure switch to shut the compressor off once the pressure on the high pressure side of the pneumatic system reaches 120 psi. The pressure gauge is self explanitory and the vent valve is used to vent all pressure outside of the system. These are all connected to each other using brass fittings and in order to ensure a good seal, and prevent air leaks, you should wrap teflon tape around all of the threads. Start two threads down from the beginning of the threads and wrap twice around the bolt. Also make sure that you wrap counter clockwise (looking from the bolt head with the end facing away from you) this is so that when you tighten the bolt you tighten the teflon tape instead of unraveling it.
Next you need to step the pressure down from 120 psi to 60 psi (or lower) you do this with a regulator. When you connect the regulator that the high pressure side is connected to the port at the tail end of the arrow (you should see an engraved arrow on the bottom of the regulator). Connect the low pressure side to the port at the head of the arrow and the remaining port should be connected to a pressure gauge to denote the pressure on the low pressure side. To change the pressure of the regulator charge up the accumulators and then pull back the lock ring on the regulator and turn the dial until the pressure is where you want it.
From here you can start adding solenoids. Solenoids are the devices you use to actuate pistons, there are two types (used in FIRST). First is single acting solenoids which switch a cylinder between two positions depending on a low or high voltage signal. When you take away the signal they will switch back to one setting (these are usually the Festo valves provided by FIRST). Single acting solenoids are usually 4 ported one port is for pressure, one for exhaust, and the other ports are connected two either end of the cylinder, or rotary actuator. Double acting solenoids are pretty much the same except the lock into position once they are switched and they have 5 ports, an extra for another exhaust port (these are usually the SMC solenoids that FIRST provides).
That's pretty much all I feel like typing now, but hey I was bored. I should have just told you to look at the pneumatics manuals, search "pneumatics" in the papers section of chiefdelphi media, and look up pneumatics in usfirst workshops section.
So go do that...now
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 29-01-2011, 18:49
We have a pneumatics page here: http://www.team358.org/files/pneumatic/
Among the first couple of documents are some step-by-step procedures that might help.
