Go to Post At least try to make sure other teams are aware of you. Don't be obnoxious, but don't be a wall flower either. - Joe Johnson [more]
Unread 29-01-2011, 12:07
soxfan269's Avatar
soxfan269 soxfan269 is offline
FIRST Team 3620 Team Member
AKA: Daniel Michaels
FRC #3620 (Average Joes)
soxfan269 is an unknown quantity at this point
Exclamation PROBLEM with opening Vision Assistant on the classmate
Every time we attempt to open NI's Vision Assistant A message comes up telling us to make the resolution higher. We have it set on the max resolution and we have put the classmates taskbar on auto hide. The message continues to come up and we aren't sure what else we can do. This happens with or without the axis camera attached. I am open to any suggestions. We are a rookie team and are using the 2011 Classmate. We are also using the Axis camera that came in the KOP.
Unread 29-01-2011, 18:42
Re: PROBLEM with opening Vision Assistant on the classmate
This was reported last year, and I suspect there is an ini token to allow the editor to operate anyway. Please post to ni.com/FRC discussions to see if it exists.
Greg McKaskle
